    CNC pattern
    32 Posts 7 Posters 2.1k Views 7 Watching
      congellous
      Thanks, Spaceclaim looks good
        Dropout
        I just did something similar. Export as an STL. Import into ArtCAM and run. Easy.
          congellous
          Is STL only available on windows, I don't have it on Mac OSX Pro 8
            Dropout
            It's a plugin. Save to DXF or something. Don't know about Mac.
              congellous
              I have designed a 3D double curving panel system with thickness on sketch up
              I now have access to a CNC machine that reads DXF or that's what the technician has asked for
              I have set the curves in maya and tested them by importing them to SKetchup
              When exported DXF obviously breaks it down into lines and I really want curves so I don't have to manually rub down the plug, is there any other option
              I'm on Mac so none of the solidworks or space claim does the job
                congellous
                Well at the risk of talking to myself, if anyone has the same issue, there is a STL exporter online
                  congellous
                  The next installment of this project is CNC cutting and SU Solid worked fine until you get to Injection Moulding or Rapid prototyping stage....
                  The companies want IGES constructed on Solidworks, I've tried STL files and the IGES plug in and it exports a mesh mess
                  Anybody doing this kind of work got any other ideas, Sketch up into Solidworks ??
                    d12dozr
                    You can export a dxf or stl from Sketchup and import that into Solidworks, but that doesn't usually cut it for injection molding. You either have to rebuild it in Solidworks, or try Spaceclaim to convert to IGES or STEP.
                    Here's mode about using Sketchup and Spaceclaim: a Youtube video
                    Sketchupdate blog post.
                    http://goo.gl/f7ooYh
                      congellous
                      Thanks, that was my conclusion too - Spaceclaim is only Windows though.
                      Is there any tips for making the transfer from sketch up to Solidworks easier, I have to translate my idea's to the product designer and an awful lot of time has already gone into it for it to be a redraw
                        sepo
                        Hi there
                        I find the best route would be via Rhino. Here is the link which explains how to take it from rhino to solidworks. You have ability in Rhino to to resurface it and use nurbs. To bring it to rhino I would sugest either .obj or .dwg.
                        http://www.rhinojungle.com/forum/topics/rhino-model-to-solidworks-for-cfd-analysis?xg_source=activity
                        hope it helps
                          sepo
                          but hey solidworks is only windows as far as I know.... rhino has open beta for Mac so that maybe your salvation.
                            congellous
                            Yeah solidworks is windows as well. Rhino uses the same manifold 3D as solidworks ? And, will it be OK for injection moulding, I know it does nurbs as I have used it in Uni
                              Maybe this can interest you (for PC)
                              Sketchup to Rhino or any Nurbs programs : format OBJ to format 3Dm πŸ˜‰
                              It's a free Prog "Obj23dmWireframe" made by Michael Gibson the creator of Moi β˜€
                              (unzipp it)
                              Just export your model from SU in OBJ format by the TIG OBJ_Exporter (if you have just free version of SU)
                              Then launch the "Obj23dmWireframe" prog!
                              You have 2 choices
                              • each segments will became a simple line (without double)
                                or more interesting!
                              • each planes faces will become a closed polylines! So can be easily a face in a Nurbs prog! πŸ‘
                                And of course can be filleted etc... 😎
                              Can of course works with any "obj file"! πŸ˜‰
                              But don't take obj files like OBJ Zbrush file (millions of polygons) πŸ˜’
                              Walk Man OBJ
                              Walk Man 3DM
                              http://moiscript.weebly.com/uploads/3/9/3/8/3938813/3531936.jpg?598
                                sepo
                                Rhino is good for injection moulding, rapid prototyping etc. You will have to make sure that nurbs surfaces do not have naked edges...means you have to produce clean geometry.
                                Btw Rhino has been used a lot in industry to convert 3rd party files to solidworks geometry.
                                As Pilou says MOI is as well good option for .3DM.
                                  congellous
                                  Thanks guys, I have Rhino up and running
                                  In some tests the STL and IGES files exported from Sketchup have various holes and anomalies and come in as meshes even after SU SOLID plug has made them water tight solids
                                  Is there a process for sorting this out, I'm trying the "fill holes" Join, weld tools etc just wondered if anyone had a process
                                    Why not try the process 3 posts above with the little prog of conversion?
                                    Sketchup --> OBJ --> 3DM --> Rhino ?
                                      congellous
                                      I'm on a Mac though ??
                                        sepo
                                        you should be able to import SU directly into rhino. saying that I am not sure if imprter is implemented in beta.
                                          congellous
                                          Yeah I can get geometry into Rhino from sketch up as polygonal mesh
                                          Is there anyway I can make this into a manifold or start creating the surfaces onto the model in Rhino, I suppose this is what spaceclaim does.....
                                            sepo
                                            There are some plugins but I believe they are mostly windows for now....
                                            Have a look at here.
                                            http://wiki.mcneel.com/rhino/meshtonurb
