    Trillion-frame-per-second video
    6 Posts 3 Posters 349 Views 3 Watching
    • KrisidiousK Offline
      Krisidious
      Visualizing Light at Trillion FPS, Camera Culture, MIT Media Lab
      (web.media.mit.edu)
      We have built an imaging solution that allows us to visualize propagation of light. The effective exposure time of each frame is two trillionths of a second and the resultant visualization depicts the movement of light at roughly half a trillion frames per second. Direct recording of reflected or scattered light at such a frame rate with sufficient brightness is nearly impossible. We use an indirect 'stroboscopic' method that records millions of repeated measurements by careful scanning in time and viewpoints. Then we rearrange the data to create a 'movie' of a nanosecond long event.
      The device has been developed by the MIT Media Lab’s Camera Culture group in collaboration with Bawendi Lab in the Department of Chemistry at MIT. A laser pulse that lasts less than one trillionth of a second is used as a flash and the light returning from the scene is collected by a camera at a rate equivalent to roughly half a trillion frames per second. However, due to very short exposure times (roughly two trillionth of a second) and a narrow field of view of the camera, the video is captured over several minutes by repeated and periodic sampling.
      The new technique, which we call Femto Photography, consists of femtosecond laser illumination, picosecond-accurate detectors and mathematical reconstruction techniques. Our light source is a Titanium Sapphire laser that emits pulses at regular intervals every ~13 nanoseconds. These pulses illuminate the scene, and also trigger our picosecond accurate streak tube which captures the light returned from the scene. The streak camera has a reasonable field of view in horizontal direction but very narrow (roughly equivalent to one scan line) in vertical dimension. At every recording, we can only record a '1D movie' of this narrow field of view. In the movie, we record roughly 480 frames and each frame has a roughly 1.71 picosecond exposure time. Through a system of mirrors, we orient the view of the camera towards different parts of the object and capture a movie for each view. We maintain a fixed delay between the laser pulse and our movie starttime. Finally, our algorithm uses this captured data to compose a single 2D movie of roughly 480 frames each with an effective exposure time of 1.71 picoseconds.
      Beyond the potential in artistic and educational visualization, applications include industrial imaging to analyze faults and material properties, scientific imaging for understanding ultrafast processes and medical imaging to reconstruct sub-surface elements, i.e., 'ultrasound with light'. In addition, the photon path analysis will allow new forms of computational photography, e.g., to render and re-light photos using computer graphics techniques.
      By: Kristoff Rand
      • cottyC Offline
        cotty
        I'm looking forward to see that principle implemented in my renderer...
        my SketchUp gallery
        • FrederikF Offline
          Frederik
          πŸ˜’ Because you need to use it for... πŸ˜•
          Cheers
          Kim Frederik
            Krisidious
            :roll: Because you need to use it for... πŸ˜•
            tracking electron usage and paths in my designs?
            By: Kristoff Rand
            • cottyC Offline
              cotty
              Or render pictures around the corner...
              my SketchUp gallery
              • FrederikF Offline
                Frederik
                Makes sense... πŸ€“
                Cheers
                Kim Frederik
