    Save coordinates in an array
    17 Posts 3 Posters 1.3k Views 3 Watching
      michaelazer
      I think I got it πŸ˜„ thank you so much TIG.
      I really appreciate your help.
      • Dan RathbunD
        Dan Rathbun
        @michaelazer said:
        I got the syntax onLButtonDown(flag,x,y,view) from the API, which I don't get, by the way.
        ... Why am I entering an X and a Y, ...
        Let me explain it specifically (and technically.)
        All the methods listed in the API dictionary, for the Tool class, are a special kind of method, termed a "callback".
        A Tool class object is an event-driven object, in this case, driven by what the user does.
        When the user starts the tool, (by clicking a menu item or a toolbar button,) the SketchUp application "calls back" into the tool instance, specifically calling the activate() callback.
        YOU are expected to overrride (ie, redefine,) this callback in YOUR custom Tool class. (Pretending here that the API Tool class actually does or hopefully will have in the future, a true superclass; .. because it really should have one. Anyway... it helps to understand basic Ruby subclassing. Most times in Ruby your custom classes will have a superclass that they inherit methods from.)
        So whatever you define in the activate() callback runs. You are free to define normal instance methods, within your class, (often coders write a reset() method that gets called from the onCancel callback, but you can also call it from within activate() and initialize(), and/or whichever other method or callback you need to.)
        As TIG said, arguments for callbacks, are passed by the SketchUp application engine.
        In event-driven code like Tool class instances, you never know which callback will get called in what order. It all depends on what the user clicks on, or what key they press. So the code does not run sequentially.
        This is why you must store references in instance variables, that ALL of the instance methods and callbacks can access. It is common to reset (or init,) these variables in a reset() method.
        Now Ruby itself, also has callback methods that are called automatically. The most important is the private instance method initialize(), which is automatically called by the public class constructor method new(), after it has created the new instance object. The new() method passes all of the arguments IT got, into the initialize() callback, of the newly created instance.
        !! Since this is Ruby Core stuff, you will not see it listed in the API dictionary. Please read the "guide" I wrote, click link in my signature tagline; follow the steps, and get the standard Ruby reference CHM and other resources, cheatsheets etc.
        But most of all.. watch out! Your about to become addicted to Ruby. πŸ˜›
        P.S.: Have you read the "Plugins/Examples/linetool.rb" ??
        I'm not here much anymore.
        • Dan RathbunD
          Dan Rathbun
          @tig said:
          Incidentally don't define the mod etc outside of the class, if you need them, define them inside the activate() and use @mod so it's accessible in all def methods...
          This is important, not only for access from all instance methods,...
          .. but because SketchUp can (via user control,) close, open, and on the Mac, switch to another model. Each model maintains it's OWN toolstack. When your tool instance gets activated, and the activate() callback gets called, within it, you need to set these model specific references to the model ( @mod), it's selection or any of this model's collection objects THIS tool instance will access.
          SO.. this is also why TIG suggested creating a new tool instance, each time the user selects your tool from the menu or a toolbar. (Even though this is considered bad form in Ruby, ... usually best practice is to create a var to hold a reference to the instance, while it's in use, and then release it, by @var = nil, so Garbage Collection can dispose of the now unneeded object. BUT... it is easier, and simplier [makes more readable code, etc.] and most of all less error-prone in SketchUp embedded Ruby, if you just let each model's toolstack hold the reference to it's own instance of your tool. When the tool is no longer in use, the toolstack will no longer reference it, and Garbage Collection will clean it up automatically.)
          To understand why this is important... think about a user on the Mac, with 2 models open.
          He is in "model one", activates your tool (which creates "instance 1" of your tool, referenced by "model one's" Tools collection (aka toolstack,)
          He clicks a point and begins drawing a line...
          But then he remembers a line he forgot to draw in "model two", and decides to do that first, before he forgets again...
          So he switches to the document window for "model two" (which causes a change in the active model,) and he then activates your line tool, for "model two"...
          At this point AN instance of your tool is the active tool in both model's toolstack, but "model two's" toolstack should reference "instance two" of your tool.
          It is important that each model's toolstack, have it's own instance of your tool. Because the tool state (tool step, whatever you call it,) may differ between each model. At this point in time model two's tools state would be 0, as no starting point has yet been picked, but the tool instance in "model one" is at tool state 1 as the user has already picked the start point.
          Your Tool class should allow the user to draw the line he forgot in "model two", then switch back to "model one" where it's OWN instance of your tool is still the active tool, and I believe the SketchUp engine will automatically call the resume() callback, which gives you the opportunity to redraw the view. Anyway the user should be able to continue where he was, with the first point already chosen.
          All this will be automatic, if you use TIG's suggestion in your menu item (or toolbar,) command blocks:
          Sketchup.active_model.select_tool(Mazer::LineTool.new)
          and have the references to the model, and it's collections, as instance vars created in the initialize() method.
            michaelazer
            Thanks Dan, I think I actually got addicted to Ruby πŸ˜„
            If I'm not asking for too much, I have a request and a question.
            Request: I theoretically understood both your comments, but can you write me a small piece of code or point me to a link to give me a practical example of how to use the resume(), activate(),new(), and initialize()? I got confused on where to put the code that I want to run when I click the Left Mouse button.
            Question: I don't understand what the @mod is. Is this a variable that Sketchup understands alone or do I need to declare it?
            Sorry, but after I thought I understood, I couldn't apply what I understood.
            Thanks a lot
            • Dan RathbunD
              Dan Rathbun
              It is an instance variable that YOU use within your custom class definition.
              Ruby does not make you define @name instance variables, before use.
              Usually they are initialized to some value, within a class' initialize() method.
              But a SU Tool class does not (usually,) do anything when it is initialized, only after it becomes active, and the activate() callback gets called. So, it's kind of take your pick.
              But it DOES make you define @@name module/class variables and NAME constants before they are accessed.
              Using the word 'declare' is un-ruby, because Ruby does not really have variables, they are actually object references. (But somebody decided they would scare off old BASIC programmers if it got out that Ruby had no variables.) Anyway, do not worry about this for now, except to know that Ruby variables/references can point at any class of object when initialized, and at anytime later, can be re-assigned to point at an object of a completely different, unrelated class.
              Realize that = is the reference assignment operator, not equals (which is == in Ruby.)
              • Dan RathbunD
                Dan Rathbun
                Links... Others and I have written and sampled our fingers raw.
                Check the [ Code Snippets ] indexes. It is one of the "Sticky" topics that is always at the top of the first forum page.
                Then use the forum search to search on "Tool" or "Tool +activate +resume" etc.
                About new(), don't worry about, because at this stage your not ready to override a class constructor. And you do not need to. Only know that after it does it's creation work, it calls initialize() in the newly created instance, passing along any arguments it itself was passed.
                So if you wish to pass something into your instance, via new(), then define initialize() with arguments in it's parameter list.
                class Bear
                  def initialize(myname,father)
                    @myname = myname
                    @father = father
                booboo = Bear.new('BooBoo','YogiBear')
                And in case you are wondering, method arguments ARE local variables, whose scope is local to the method.
                But these 'locals' will "go out of scope" when the method ends, and the objects they point at, will become unreferenced.
                So.. we create instance variable references (whose scope is the entire instance,) that are assigned to point at those same objects; .. and after the method ends, these objects are still referenced, and will not be Garbage Collected.(ie, GC'd, as we say.)
                So, this:
                @myname = myname
                means:
                The reference @myname (shall be created if not,) and assigned to point at the object, that myname is pointing at.
                  michaelazer
                  Really, Dan, I can't thank you enough. I think I now have my feet on the right path.
                  I believe I will be a regular here on this forum. Again, many thanks to you and TIG.
                    michaelazer
                    After I got your comments I worked on my program, I wrote the following code:
                    class MyTool
                    		# Initialization
                    	def activate
                    		@input = Sketchup;;InputPoint.new
                    		@pts[]
                    	# Respond to left click
                    	def onLButtonDown flags, x, y, view
                    		@input.pick view, x, y
                    		sketchup;;set_status_text "Left click ", SB_VCB_LABEL
                    		pos = @input.position
                    		@pts << pos
                    		str = "%.2f, %.2f,%.2f" % [pos.x, pos.y, pos.z]
                    		Sketchup;;set_status_text str, SB_VCB_VALUE
                    # Create Command object
                    simple_cmd = UI;;Command.new("Click") {
                    	Sketchup.active_model.select_tool MyTool.new
                    #Add command to tools menu
                    tool_menu = UI.menu "Tools"
                    tool_menu.add_separator
                    tool_menu.add_item simple_cmd
                    But still something is not right! I'm getting the following error:
                    Error: #<NoMethodError: undefined method <<' for nil:NilClass> C:/Program Files/Google/Google SketchUp 8/Plugins/click.rb:14:in onLButtonDown'
                    Can you please help me out? Thanks!
                    • Dan RathbunD
                      Dan Rathbun
                      It's just a couple of typos.
                      Line 6 should be:
                      @pts = []
                      so it is defined as an empty Array.
                      Line 12 needs to spec the Sketchup module with a captial first letter. (All module and class Identifiers in Ruby are constants. Constants begin with a capital letter.)
                      P.S.: Constants values are traditionally ALLCAPS. πŸ€“
                      And... please learn to wrap ALL your code with a toplevel module with your unique name, before you release anything.
                        michaelazer
                        Thank you so much, Dan. Your tips solved the problem.
                        Now, I have the program running, but I don't get the correct coordinates.
                        I was expecting to get some positive and some negative, according to where I am from the axes.
                        I clicked the 4 corners of the screen and I got the following, which doesn't look right:
                        x: 46 y: 48 z: 48
                        x: 53 y: 52 z: 46
                        x: 54 y: 57 z: 46
                        x: 52 y: 46 z: 56
                          michaelazer
                          x: 46 y: 48 z: 48
                          x: 53 y: 52 z: 46
                          x: 54 y: 57 z: 46
                          x: 52 y: 46 z: 56
