    Auto create street blocks
    7 Posts 3 Posters 743 Views 3 Watching
      Kenny
      I'm hoping someone might be able to tell me if the following is possible. I'm working on a large housing masterplan at the moment and I've set out the development blocks. My next job is to insert the houses. This is very time consuming and I'm wondering if there is a script that could be created to achieve the attached. I suppose a cross between component spray and path copy would start to address what is required.
      Essentially the block edges and required house components are selected then parameters would be input. These would be distance from block edge, spacing between components, alignment (parallel to edge) and if possible, rules for turning corners where a distance from the rear face to the side gable is input (It would probably be green to red axis edges). It would be great if this were possible and any suggestions would be appreciated.
      http://www.townscapesolutions.co.uk/
        Components stringer
        City Street generator
        Modelur
          Kenny
          Thanks for the reply and the suggestions. All are useful however none of them give me the result I'm looking for.
            Kenny
            I'm presuming this is probably not possible, however if anyone thinks it can be done there is a fee available if you PM me.
            This software does something similar, however I'd far rather work within Sketchup. :
            404 Not Found
            (www.holisticcity.co.uk)
            • KrisidiousK Offline
              Krisidious
              might this do it? cut up lots for you? maybe not...
              http://forums.sketchucation.com/viewtopic.php?f=323&t=46696#p417578
              By: Kristoff Rand
                Kenny
                Thanks Kristoff it looks interesting but won't achieve what I'm after.
                  Krisidious
                  yeah sorry... I would like something that was able to cut up plots of land in to lots of certain sizes. like 1/4 acre or 1/2 acre lots out of a large parcel.
                  By: Kristoff Rand
