    Spaceship (Collaborative Project)
    281 Posts 14 Posters 44.2k Views 14 Watching
    • iichiversiiI Offline
      iichiversii
      What about making it wider like in this image, make it look more menacing
      ALTERATION_STARSHIP_CONCEPT.skp
      The image is far wider than the skp file, check it out πŸ‘
      Bring on the Rain...
      • MarianM Offline
        Marian
        Yeah, but it's not as sleek. Maybe a bit wider would be ok but that is way to wide.
          iichiversii
          Hows this?
          • MarianM Offline
            Marian
            Neah...
            LOWERPOLY_STARSHIP_CONCEPT.skp
              iichiversii
              You nailed it there, much better πŸ‘
              • MarianM Offline
                Marian
                Yey. πŸ˜„
                What's next?
                  iichiversii
                  If all else fails Marion at least we have a shuttle πŸ˜†
                  • MarianM Offline
                    Marian
                    Meh...I don't want a shuttle. πŸ˜›
                      iichiversii
                      @marian said:
                      Yey. πŸ˜„
                      What's next?
                      I think the main body is next, since the front section is more or less on top/front it looks like we are going to need to build the main body from the top down, I usually work from the bottom up, but so far we have an interesting front section, it reminds me if the miny sub used in the DSV series if you remember, it operated like a dolphin where the tail worked like an organic flipper, I loved that show until it was cancelled, so main body, suggestions? Iv an idea that comes to mind which I'll work on later tonight πŸ˜„
                      • MarianM Offline
                        Marian
                        Oh yes, I loved Seaquest too untill they went all Star Trek and then batshit crazy
                        y.
                        Yeah..keep it lowpoly and similar in style with the front, but I also may make something for the main body. πŸ˜„
                        • MarianM Offline
                          Marian
                          πŸ˜„
                            iichiversii
                            That is very nice, let's keep that πŸ‘
                            • MarianM Offline
                              Marian
                              Cool. So we could make the front separable in case of emergencies. I don't want to add big engines on it.
                                iichiversii
                                Excellent idea, a lifeboat like onboard the USCSS PROMETHEUS and ENTERPRISE, clever, aslong as its not noticeable, it should be completely flushed with the ship and only becomes noticeable when it separates, like the enterprise, the USCSS PROMETHEUS lifeboat was consealed inside the ship if I remember correctly, great idea Marian πŸ‘
                                • MarianM Offline
                                  Marian
                                  What do you think?
                                    iichiversii
                                    Interesting, I need to view the model to criticise, I had a different idea myself, once I finish work today I'll post up what I had bouncing around in my mind, but from the image it looks great πŸ‘
                                    • MarianM Offline
                                      Marian
                                      I may have to discard the big body or think of another way to attach it. It's not very elegant at the moment. I'm curious to see what you come up with.
                                        iichiversii
                                        I think you might not like this idea I have, πŸ˜†
                                        But I will model it later for you to criticise, I'm going to try and beef it up a little but keeping the design of the cockpit/lifeboat the same with 1 alteration to its underside, in my mind it works but sure we will see later πŸ‘
                                          iichiversii
                                          Dont you just hate it when you model something and it crashes 2 hrs later and then you remember you didnt save it, 🀒
                                          I had something really nice modelled for this and now its gone πŸ‘Ž
                                          • MarianM Offline
                                            Marian
                                            That very seldom happens to me.
                                            I leave the autosave to 5 minutes so even if I don't save and SU crashes I still have an up to date backup most of the times. If you've left the default setting it should ask you upon restarting SU if you want to open that autosave. If it doesn't it might still be somewhere in the My Documents folder.
                                            • 14
                                            • 15
                                            • 4 / 15
