    How to import several models to designated positions
    13 Posts 4 Posters 1.0k Views 4 Watching
    • lbsswuL
      lbsswu
      I want to import three car models to designated positions. These position are designated by 3D coordinates, e.g. [0,0,0], [0,200,0], [100,0,0]. I want to do this just by script, without mouse. Could any one help me?
      • K
        kwalkerman
        Take a look at entities.add_instance:
        https://developers.google.com/sketchup/docs/ourdoc/entities#add_instance
        and the DefinitionList, especially DefinitionList.load and DefinitionList.load_from_url:
        https://developers.google.com/sketchup/docs/ourdoc/definitionlist
        Karen
          If the models are not SketchUp models, look at:
          Model.import
          https://developers.google.com/sketchup/docs/ourdoc/model#import
          • lbsswuL
            lbsswu
            Karen
            I got it. Thanks very much!
            • lbsswuL
              lbsswu
              Model.import
              My original models are .3ds. Thanks for your tip!
              • lbsswuL
                lbsswu
                @thomthom said:
                I had a look at model.import and found that it annoyingly didn't return the definition to the imported model. Instead it activates a tool for the user to place it.
                I created this little snippet that worked around that and placed the imported model at a given coordinate:
                <span class="syntaxdefault"><br />module Test<br /><br />  def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">import_3ds</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> file </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">'c;/cube.3ds'</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> position </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> ORIGIN </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    model </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />    </span><span class="syntaxcomment"># Cache camera position because model#import will change it.<br /></span><span class="syntaxdefault">    camera </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">camera<br />    eye </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> camera</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">eye<br />    target </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> camera</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">target<br />    up </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> camera</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">up<br />    </span><span class="syntaxcomment"># Begin import operation.<br /></span><span class="syntaxdefault">    model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start_operation</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> </span><span class="syntaxstring">'Import 3DS Model'</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> false </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># Cache existing list of definitions.<br /></span><span class="syntaxdefault">    cache </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definitions</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_a<br />    </span><span class="syntaxcomment"># Import model, this will attach it to the cursor.<br /></span><span class="syntaxdefault">    model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">import</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> file </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select_tool</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> nil </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxcomment"># Deactivate Place Model tool.<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># Find root definition because the import creates multiple definitions.<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># The sub-components are maked as #internal? - so we look for the one<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># without the mark.<br /></span><span class="syntaxdefault">    imported </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definitions</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_a </span><span class="syntaxkeyword">-</span><span class="syntaxdefault"> cache<br />    definition </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> imported</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">find </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">d</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">!</span><span class="syntaxdefault">d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">internal</span><span class="syntaxkeyword">?</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># Place instance in current context.<br /></span><span class="syntaxdefault">    tr </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Transformation</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault"> position </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_instance</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> definition</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> tr </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># Restore camera.<br /></span><span class="syntaxdefault">    camera</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> eye</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> target</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> up </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># Finished! ;)<br /></span><span class="syntaxdefault">    model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">commit_operation<br />  rescue<br />    model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">abort_operation<br />    raise<br />  end<br /><br />end </span><span class="syntaxcomment"># module<br /></span><span class="syntaxdefault"> </span>
                I test the code, it works well. Thanks!
                But now I find a problem about the given coordinate which is designated by me. After importing the model, the position of the model may not be the one I designated. This is because of the file I want to import. Use the Bed.skp file as an example. Suppose I have two Bed models as these in the attachment, if I import them into sketchup with the same given coordinate, after importing, however, the positions of them are not same.
                I want to import model with its center at given coordinate in sketchup, no matter where the model is in the import file. Is there any way to implement it?
                first type of model I want to import
                second type of model I want to import
                  Ah, then you would find the centre of the imported model based on its bounds - and work out where its origin is relative to this centre.
                  • Dan RathbunD
                    Dan Rathbun
                    Why not get the selected component instance BEFORE you deactivate the MoveTool ???
                    Then you can get the instance's definition without all that search part.
                    AND... There IS a standard Ruby module Test (and the API added a few methods in there,) that should really not be modified.
                    Something like this... wrap inside a module Temp, or at the very least, in a submodule of Test, such as... Test::Import
                    I'm not here much anymore.
                      Oh... the instance is in model.selection ? duh!
                      There is a Test module part of the Ruby that ships with SketchUp?
                      • Dan RathbunD
                        Dan Rathbun
                        YES. And.. John H & Co. added test methods to it:
                        Test.methods(false).sort
                        %(#000000)[>>] %(#008000)[["AutoClickTime", "AutoClickTime=", "AutoDragDistance", "AutoDragDistance=", "CorruptModel", "FindFile", "eat_mem", "face_to_mesh", "flip_images_for_origami", "project_textures_from_photo", "show_fps", "time_display", "time_pick", "use_sg_off_screen", "use_sg_on_screen"]]
                        This is the same module that gets defined when you use the Standard Library Extension for unit testing. However.. in this case the Test module is only used as a namespace. (That is not to say that other library extensions, might add methods to module Test.)
                          flip_images_for_origam 😲
                            <span class="syntaxdefault"><br />module Testbed<br /><br />  def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">import_3ds</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> file </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">'c;/cube.3ds'</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> position </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> ORIGIN </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    model </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />    </span><span class="syntaxcomment"># Cache camera position because model#import will change it.<br /></span><span class="syntaxdefault">    camera </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">camera<br />    eye </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> camera</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">eye<br />    target </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> camera</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">target<br />    up </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> camera</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">up<br />    </span><span class="syntaxcomment"># Begin import operation.<br /></span><span class="syntaxdefault">    model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start_operation</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> </span><span class="syntaxstring">'Import 3DS Model'</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> false </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># Cache existing list of definitions.<br /></span><span class="syntaxdefault">    cache </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definitions</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_a<br />    </span><span class="syntaxcomment"># Import model, this will attach it to the cursor.<br /></span><span class="syntaxdefault">    model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">import</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> file </span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">instance&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">definition&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">instance</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definition<br />    model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select_tool</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> nil </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxcomment"># Deactivate Place Model tool.<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># Place instance in current context.<br /></span><span class="syntaxdefault">    tr </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Transformation</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault"> position </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_instance</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> definition</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> tr </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># Restore camera.<br /></span><span class="syntaxdefault">    camera</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> eye</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> target</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> up </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># Finished! ;)<br /></span><span class="syntaxdefault">    model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">commit_operation<br />  rescue<br />    model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">abort_operation<br />    raise<br />  end<br /><br />end </span><span class="syntaxcomment"># module<br /></span><span class="syntaxdefault"> </span>
                            'Cube.3ds' test model
                            • Dan RathbunD
                              Dan Rathbun
                              When I first listed the methods, I thot for a moment (until I looked twice,) that the seventh method was named eat_me! ... 🤣
