    Get the coordinates of the corners of the "blue box"
    7 Posts 3 Posters 468 Views 3 Watching
      dacastror
      Hello, I would like to know how I can get the coordinates of the 8 corners of the "blue box" of a group or component that has been rotated and scaled
      https://sites.google.com/site/dacastror/archivos/extremos box 2.jpg
      I tried to bounds.corner or local_bounds.corner but do not work properly for what I need, I have been looking and I could not find the appropriateness
        dacastror
        help 😢
        • Dan RathbunD Offline
          Dan Rathbun
          @dacastror said:
          help 😢
          http://forums.sketchucation.com/viewtopic.php?f=180&t=46183&p=413432
          I'm not here much anymore.
            dacastror
            I know you helped me very much, sorry for asking much just I want to learn
              Check out the source of this plugin that draws edges of the boundingbox: http://forums.sketchucation.com/viewtopic.php?t=29377#p256536
                dacastror
                Thom thank you very much.
                I know I need this in lines 66 to 68 of your code:
                definition = self.get_definition(entity) bb = definition.bounds pts = self.bound_points(bb).map { |pt| pt.transform( entity.transformation )
                is a shame that is not yet ready to understand these lines clearly, however I will be very useful, very grateful
                (sorry for my bad English)
                  Get's the ComponentDefinition of the ComponentInstance or Group
                  Get's the bounds of the definition - note that if you get the bounds of the instance it will be a Boundingbox aligned to the model axis - not the instance axis. Which is why you need to get the definition bounds.
                  Now transform the points of the definition boundingbox with the transformation of the instance.
                  In other words, get the boundingbox of the definition and apply the instance transformation to the coordinates of that boundingbox.
                  With your input, this post could be even better šŸ’—
