[Code] Win32 - Get SketchUp Window Handle (WIP)
GetCurrentThreadIdI think this one is what we can use to get associated window handles. Just need to get callbacks working so we can useEnumThreadWindowsto get the windows for the calling thread. -
@jim said:
@thomthom said:
Where is the win32-api found - the one that supports callbacks?
http://win32utils.rubyforge.org/
I'm not sure if this can co-exist with Win32API or not.
require 'win32/api'
[attachment=0:26ojrmbj]<!-- ia0 -->win32.zip<!-- ia0 -->[/attachment:26ojrmbj]I just tried it, works fine with Win32API.
Here's a bastardised proof of concept snippet where I found the SketchUp window regardless if it had focus or not.
# http://stackoverflow.com/questions/3327666/win32s-findwindow-can-find-a-particular-window-with-the-exact-title-but-what EnumWindows = Win32;;API.new('EnumWindows', 'KP', 'L', 'user32') EnumThreadWindows = Win32;;API.new('EnumThreadWindows', 'LKP', 'I', 'user32') GetCurrentThreadId = Win32API.new("kernel32.dll", "GetCurrentThreadId", '', 'L') # Detect the toolwindows even if Hide Dialogs is active. def enum_sketchup_windows threadId = GetCurrentThreadId.call enumWindowsProc = Win32;;API;;Callback.new('LP', 'I'){ |handle, param| #puts "EnumWindows - Callback" #puts "> handle; #{handle}" #puts "> param; #{param.inspect}" window_text = get_window_text(handle) window_text.strip! # Remove trailing NULL character p window_text unless window_text.empty? if !window_text.index(param).nil? puts "window was found; handle #{handle}" 0 # FALSE - stop looking after we find it 1 # TRUE else 1 # TRUE end } EnumThreadWindows.call(threadId, enumWindowsProc, 'SketchUp') end # Takes the first enumerated window for the calling SketchUp thread and fetches # the root owner which should be the SketchUp window. (Not tested against wxSU) # # Is the enum required to get just one window? Any other function to get an # arbitrary window from the SketchUp thread? def find_sketchup_window threadId = GetCurrentThreadId.call hwnd = 0 enumWindowsProc = Win32;;API;;Callback.new('LP', 'I'){ |handle, param| hwnd = GetAncestor.call(handle, GA_ROOTOWNER) 0 } EnumThreadWindows.call(threadId, enumWindowsProc, 'SketchUp') hwnd endRemaining issues:
- Migrate
Win32APItoWin32::APIfor all function calls. - While testing I eventually got an exception that said there was too many callbacks initiated. Seems there might be a limit. I have not looked into this further, but I think once might have to make one callback proc, and then delegate to the appropriate handling method based on
param.
- Migrate
= Documentation
The source file contains inline RDoc documentation. If you installed
this file as a gem, then you have the docs.Where do you get the source code?
I tried to install the gem, but got this error:
It is a c-language based extension, and apparently isn't available already compiled for your platform. So you would need to compile it.
This is the advantage of using the mingw32 Ruby Installer with devkit - it automatically builds native libraries.
But where is the source code - since it's suppose to contain the documentation?
For me, it is here:
C:\Ruby186\lib\ruby\gems\1.8\gems\win32-api-1.4.7-x86-mingw32\ext\win32 -
hm... guess I have to look into that ming-thing...
Anyway - I have produced a code which appear to return the handle for the SketchUp window of the calling thread. I created a EnumWindowsProc to delegate enumeration messages in order to avoid
Error: #<Win32::API::Error: too many callbacks are defined.>. I really want to know what this limit is. This is the first draft, I expect there is a better way to deal with this.But, we do get a reliable window for the SketchUp window we want - as far as I have been able to test.
Maybe we can handle drag and drop by callbacks. Or intercept window messages so we can simulate the roll-up/down of toolwindows.
Still, OSX users are out of luck here...
Here's some interesting info:
# # some Sketchup window properties; # # AutomationId = "" # # CLASS = "Afx;00400000;b;00010011;00000006;00790557" # *** the last octet changes each time Sketchup is run, # examples; "Afx;00400000;b;00010011;00000006;0012077F" # "Afx;00400000;b;00010011;00000006;000E0699" # # ControlType = "ControlType.Window" # LocalizedControlType = "window" #The main application window is the only one with a classname like this, and also the only one with a LocalizedControlType that equals "window".
ALL dialogs including WebDialogs, are:
# # ClassName = "#32770" # ControlType = "ControlType.Window" # LocalizedControlType = "Dialog" # -
Are you planning on distibuting a pre-compiled win-api as part of TT_Lib2 ??
I have a few issues with this.
(1) It's not in the correct folder. What if a person already has it (and possibly a newer version,) installed ?require will not recognize the path string you have in that example, and would load the older version down under your TT_Lib2 folder. That would overwrite the newer classes that might be loaded, if they were loaded first.
OR.. since "T" comes before "W" your version would get loaded first, and when a normal version gets loaded after... your code might get broken. (I say "might" as newer versions are usually better.)
So? I like the idea of someone precompiling Berger's WinUtils, and zipping them for manual install by the community (and/or creating a one-click-installer for dummies.) But they should be in the proper folder ... and likely a path to them appended to the $LOAD_PATH array.
How much of Berger's suite would the distro have? the bare bones min or the whole thing?
I get
Afx:00A50000:b:00010005:00000006:0A7C0E3Bduring one session,
and the next I getAfx:00ED0000:b:00010005:00000006:5CCC0D4F- seems to be more than just the last bit that changes...SU8 - Win7...
I don't understand where that name is from - other apps, like Notepad++ has a fixed classname.
I'm looking into it. If license allows it.
That is a thing that was on my to-look-into list. What if I placed it into a folder, say:
TT_Lib2/win32api/win32/api.so- and then added theTT_Lib2/win32api/path to$LOAD_PATHso one load it as the examples saysrequire 'win32/api'?@dan rathbun said:
We have that potential issue with Win32API already, though it often lies in the root of the plugins folder, you can't be sure what version was copied into there last.
Atm I only have use of
api.so- but there was some interesting stuff he had. -
@thomthom said:
I get
I don't understand where that name is from- other apps, like Notepad++ has a fixed classname.
(http://en.wikipedia.org/wiki/Application_Framework_eXtensions)":35xuu8cn]One interesting quirk of MFC is the use of "Afx" as the prefix for many functions, macros and the standard precompiled header name "stdafx.h". During early development what became MFC was called "Application Framework Extensions" and abbreviated "Afx". The name Microsoft Foundation Classes (MFC) was adopted too late in the release cycle to change these references.
Just few words about AFX:XXXXX:XXX like windows..... Dont confuse with this type of class names, these are just class names and actually MFC generates class names for its windows this way. Some of those numbers are an HINSTANCE and a process ID (to make sure the class name is unique). I'm not sure what the others are - if you really want to know, you can probably find it in 'MFC source code. -MAHESH
(http://www.autohotkey.com/forum/topic633.html), Chris, in his reply, ":35xuu8cn]Below are quotes from the only relevant link discovered on Google at:
Those Afx window classes were custom classes distributed with early versions of MFC, before the "Common Controls" concept was introduced.
Many people have tried to "read" text from them but you CAN'T, not with messages anyway!
They're almost certainly owner-drawn - the text is not delivered by messages, it's "hand-drawn" into the window's DC
Apparently legacy from the early days ... there are many things I see (about Sketchup UI objects,) poking about with MS Tools that don't look quite right.
So, many of what looks like system UI elemens is not drawn by the system - but emulated by the AFX/MFC framework?
There are several GUI frameworks a coder can choose to use ... WTL sounds very interesting.
@dan rathbun said:
I've also read that the DL library is 'on the outs', and they are planning to deprecate it and replace it with something else.
OK.. now I remember what the next generation (after DL,) was supposed to move to, (the Foriegn Function Interface):
Wikipedia: libffi
and the github site for Ruby FFI is:
https://github.com/ffi/ffiIt is not yet included with Ruby as of v1.9.1-p429
Here is my way to find sketchup window.
I used it in SU Window Settings plugin.Parts of ClassName change After restarting SU
~sample: "Afx:00400000:b:00010011:00000006:0574025D"
From my testing:- On windows XP, the last set of values, separated by ":" change.
Afx:00400000:b:00010011:00000006:0574025D - On windows 7, all even parts, separated by ":" change. The odd parts are always the same, including on both 32 and 64 -bit processors.
So, the only parts of class that are reliable to locate main SU window are, Afx, b and 00000006. Plus to get the current sketchup window, you could add the
Process.pid. The code below does all of that work
@main_window = Hash.new @find_main_window = Win32;;API;;Callback.new('IP', 'I'){|hwnd, lParam| p = 0.chr*4 threadID = GetWindowThreadProcessId.call(hwnd, p) pid = p.unpack('l')[0] next true if (pid != Process.pid) cname = 0.chr*50 GetClassName.call(hwnd, cname, cname.size) cname = cname.strip if (cname[0,3] == "Afx") and (cname[13,1] == "b") and (cname[24,8] == "00000006") @threadID = threadID @main_window["hwnd"] = hwnd next false end true } EnumWindows.call(@find_main_window, nil)Note, this example was only tested on Windows XP and On Win7.
What vous think?
You neglect to show the
require()staement that loads Dan Berger's win32-api extensions. (This example does not use the Win32API.so file, that comes "out-of-the-box" with Ruby.) -
I find it much simplier.. to use a KNOWN child window (sometimes I use the Console window, sometimes I create a hidden child window with a caption that is unique, like perhaps I insert a time-stamp and the current Sketchup pid, returned with
$$, into my child window caption.)Then find the handle to that unique window, and get it's owner.
require()staement that loads Dan Berger's win32-api extensions. (This example does not use the Win32API.so file, that comes "out-of-the-box" with Ruby.)Thanks for pointing that out. Yep, the code above requires win32-api
