    Webdialog - trouble passing array from JS to Ruby
    12 Posts 4 Posters 1.8k Views 4 Watching
    • Dan RathbunD
      Dan Rathbun
      First of all... using UI.messagebox as a debugging tool is a bad idea.
      They often fail silently, if the message argument is not correct, or there are Type mismatches in the expression.
      Get in the habit on opening the Ruby Console, and using puts() to output debug strings.
      And you can use the .to_s() or .inspect() methods to be sure the output is String compatible:
      my_dialog.add_action_callback("get_array") do |web_dialog,yv_array|
        puts "YV_array from callback action; " + yv_array.inspect
      Also the double-quoted String parameter replacement notation, #{*expression*}, has built-in text conversion for many Ruby base classes.
      So this may also work:
        puts "YV_array from callback action; #{yv_array}"
      I'm not here much anymore.
      • Dan RathbunD
        Dan Rathbun
        @aerilius said:
        If I am right the webdialog returns a string, for example %(#000000)["[1,2,3]"]
        Or you eval the array ...
        Yup you are correct, and eval() is the simplest way.. provided that on the Js side, you build the strings so Ruby's eval() can read them.
        (https://developers.google.com/sketchup/docs/ourdoc/webdialog#add_action_callback)":1lvv2jxf]Your JavaScript in the webdialog will invoke the callback method with a string representing arguments to the callback method.
        • Dan RathbunD
          Dan Rathbun
          Make sure to read by Thomas Thomassen (ThomThom)
          PDF download: WebDialogs - The Lost Manual β€” R1 09 November 2009
          SCF Forum Post: WebDialogs - The Lost Manual β€” R1 09 November 2009
            Aerilius
            The webdialog returns a string, for example %(#000000)["[1,2,3]"]. In Ruby, you always need to have a clear idea what type your value has. In JavaScript, you can mix incompatible types hoping that it will convert it and work as expected, but not in Ruby.
            Don't miss to read the Ruby Newbies Getting Started Guide
            If you apply an index to a string, you get the character code of the character at that index, example
            "string"[0] = 115 # corresponds to 's'
            When you later added a string + the arraystring, you got the expected result because both were strings. You can't add an array to a string, because it would give:
            Error: #<TypeError: (eval):151:in+': can't convert Array into String>The **+** method is not defined for different types. It exists separately for Numeric, for [Strings](http://www.ruby-doc.org/docs/ProgrammingRuby/html/ref_c_string.html#String._pl) and for [Arrays](http://www.ruby-doc.org/docs/ProgrammingRuby/html/ref_c_array.html#Array._pl), and if you have different types, you have to convert them into the same so that you can use one of the methods for it (either with array.to_sor array.inspect`).
            You could either parse the string into an array for example
            @yv_width_array_rs = yv_width_rs[1..-2].split(",")
            which returns an array of strings.
            If it should be floats (or integers) then you loop over the resulting array with collect and convert each string of a float into a float with [to_f](http://www.ruby-doc.org/docs/ProgrammingRuby/html/ref_c_string.html#String.to_f):
            @yv_width_array_rs = yv_width_rs.scan(/\d+/).collect{|d| d.to_f} # or d.to_i
            begin
              @yv_width_array_rs = eval(yv_width_rs)
            rescue
              @yv_width_array_rs = []
            which you should absolutely avoid if there is an alternative way.
              When you experience trouble with Ruby <-> JavaScript check the compiled string you send backwards and forwards. You will when quickly see syntax errors.
                rvs1977
                Thank you all!! Now I have something to try out. πŸ˜„
                Get a Ruby
                • Dan RathbunD
                  Dan Rathbun
                  begin
                  > rescue
                  > end
                  Here's a good place to show, how to use the rescue keyword, in modifier position (and save 4 lines of code.)
                  @yv_width_array_rs = eval(yv_width_rs) rescue []
                    rvs1977
                    Aerilius, Im a little impressed.
                    When you quote my code, you use different variable-names than the ones from my example.
                    The funny thing is, the variable-names you use is the one I actually use on my own computer, before I started to look at arrays... Are you psychic or something?? πŸ˜„
                    Get a Ruby
                      Aerilius
                      I'm not psychic but rather impressed/surprised myself. That are the variable names that you posted πŸ˜’ and after submitting my response, you had modified/improved the original question that I didn't recognize it anymore πŸ˜„
                        rvs1977
                        ah ok πŸ˜„
                        Anyway, it finally works with this "simple" solution:
                        @YV_array = yv_array.scan(/\d+/).collect {|d| d.to_i}
                        I wonder why the eval-rescue solution has to be avoided? Is it slow?
                        Thanks to all of you. - Aerilius, Dan, Thomthom
                        Gratias Ad Omnes
                        Get a Ruby
                        • Dan RathbunD
                          Dan Rathbun
                          ALL String operations in Ruby 1.8.x are slow.
                          eval() is the Ruby code parser.. so it is a very large method (actually a C-side function.)
                          But I cannot see it being slower than the 2 iterator methods you are using, in addition to the type converter.
                          But it works... and you understand how it works. If speed is not an issue, then go with it ...
                          πŸ‘
                          Also if you KNEW each numeric was separated by a "," then you also do:
                          @YV_array = yv_array.split(',').map{|i| i.to_i}
