    [Code] YARC – yet another ruby console
    22 Posts 4 Posters 5.4k Views 4 Watching
      Aerilius
      I added a screenshot.
      @dan rathbun said:
      I am not sure why you were sending the height and width, and calculating bordersize and titlebar size in Ruby, and saving them in instance variables.
      That was some code that I used for determining the webdialog size from the content (so that I don't have to hardcode it and it can't conflict with different rendering/fonts/zoom settings). It makes sense for static dialogs that a user shouldn't be able to resize, but I see it doesn't make sense here (other than makeing things complicated). I'll see how it works without.
        @dan rathbun said:
        But there is still a problem with new height being remembered, both during the session and on restart. (It's like the height is hard-coded.)
        A new position, is not remembered during the session, but only on the next restart.
        Yes, it's an annoying WebDialog thing. If you close and reopen the webdialog within a session it doesn't remember the new position or size until the next session. 😞
        • Dan RathbunD
          Dan Rathbun
          @dan rathbun said:
          @dan rathbun said:
          Updated again, to ver 0.6.2, fixed the location and sizing of the WebDialog. (It now remembers where it the user puts it and it's size.)
          Actually it seems.. there are still a few issues with positioning:
          Well, because of the state of the API Dictionary.. I can no longer remember what is bugged and what is not!
          (http://forums.sketchucation.com/viewtopic.php?f)":2mfzj5er]Haven't checked it out, but on PC the position is stored between sessions, but not within sessions. If you make a webdialog, close it, then open it again it doesn't remember the last position - only the last position from last session.
          I haven't noticed because I am using Win32API calls to control where my Console is (.. I guess I gave up on Sketchup doing it. We can only wait so long for the vendor to fix bugs.)
          I'm not here much anymore.
          • Dan RathbunD
            Dan Rathbun
            There is a way around this issue.. but I hate it. It's not best practice.
            You create a NEW instance each time the WD is opened, and abandon the old instance when it's closed.
            You'll lose any info and snippet links I think.
              So instances remember it... I see. They read the last position when the WebDialog initializes.
              Good point about the Win32API, for my WebDialog wrapper in TT_Lib I can add that. ..though OSX only... creating new instance isn't ideal in many of my cases because I want to preserve the content throughout the session. 😕
              • Dan RathbunD
                Dan Rathbun
                Yepper... you (and Aerilius,) would have to write to a log, and restore it on open.
                Actually, Aerilius is already saving the commands... he could just iterate them, and re-eval them to restore the output.
                And perhaps the snippets are already saved in a "snippet" directory ??
                • Dan RathbunD
                  Dan Rathbun
                  Here's ver 0.6.1 with all the mods below added in for the "ae_Console/Console.rb" and "ae_Console/Console.htm" files.
                  Updated again to ver 0.6.3 (It REALLY now remembers where it the user puts it and it's size. We let Sketchup do the work here.)
                  !! Closing the dialog will clear it contents, and wipe out command snippets !!
                  ae_Console_0_6_3.rbz
                  ae_Console_0_6_3.zip
                  Add class variables to hold the various singleton instance objects:
                  @@console_dlg = nil
                  @@command  = nil
                  @@topmenu  = nil
                  @@menuitem = nil
                  (see bottom of post...)
                  The open instance method should be named create and return a reference to the newly created UI::WebDialog instance:
                      (OSX)? @console_dlg.show_modal ; @console_dlg.show
                      return @console_dlg
                  Then the instance open method should be:
                    def open
                      dlg = @console_dlg
                      if OSX
                        dlg.visible? ? dlg.bring_to_front() ; dlg.show_modal()
                      else # WIN
                        dlg.visible? ? dlg.bring_to_front() ; dlg.show()
                  And the class method AE::Console.open()
                    def self.open(instance)
                      if @@console_dlg.nil? # nil if not yet instanced.
                        @@console_dlg = instance.method(;create).call # also opens it.
                      else
                        # The WebDialog instance exists, just open it.
                        instance.open()
                  Lastly, I always suggest putting the "Run Once" block inside your namespace.
                  (at the bottom of the file...) and the file_loaded() inside that block to prevent multiple entries in the $loaded_files array.
                  (Actually, file_loaded() will not insert duplicates, but .. why call a method if you don't have to?)
                  unless file_loaded?(File.basename(__FILE__))
                    $old_stdout = $stdout if !$old_stdout # in case you want to turn off traces
                    $stdout = AE;;Console.new
                    $stderr = $stdout # trap error displays as well
                    @@command = UI;;Command.new("Ruby Console (WebDialog)"){
                      self.open($stdout)
                    # Menu
                    @@topmenu = UI.menu("Window")
                    @@menuitem = @@topmenu.add_item(@@command)
                    file_loaded(File.basename(__FILE__))
                  end # class Console
                  end # module AE
                  Then you can (your choice,) provide class getter methods for singleton objects, that make sense. Ie, references that some other organizer script, might need a handle to:
                    # Provide a handle to the command, in case
                    # some other script wants to add it to a toolbar.
                    def self.command
                      @@command
                  • Dan RathbunD
                    Dan Rathbun
                    So use minimize, instead of close, if you wish to keep these things.
                    See second post for d/l
                      Anton_S
                      I recommend putting the whole __FILE__ instead of a File.basename(__FILE__). That way you would eliminate same filenames that are in different folders.
                      EX:
                      Plugins/Anton_Lib/core.rb
                      that statement would be true
                      ` unless file_loaded?(File.basename(FILE))
                      file_loaded(File.basename(FILE))end`
                      Plugins/TT_Lib/core.rb
                      that statement would be false, preventing vital parts to be called
                        @anton_s said:
                        I recommend putting the whole FILE instead of a File.basename(FILE). That way you would eliminate same filenames that are in different folders.
                        +1
                        I have adopted the same pattern myself. Just using the filename is not a unique ID - full path is. It doesn't even have to be a filename you feed file_loaded - just any unique string.
                        • Dan RathbunD
                          Dan Rathbun
                          Yup we've talked a bit about this before. (I didn't change what he had in his code. I thot it might be too far off topic.)
                          I've posted a new topic on this subject:
                          [ Code ] custom file_loaded() and file_loaded?()
                          @Anton_S: I sent you a personal edition via PM, check your inbox.
                            Anton_S
                            yep, sure
                              Aerilius
                              That's very reasonable. I'll fix it.
                              I just wanted to let you all know that I'm working on improvements (esp. the snippets should have been saved over sessions) but I'm a bit busy at the moment. I'll publish a next version when I'm ready.
