[Plugin] SectionByCamera (V0.2) - UPDATED 4 June 2012
thanks I'll give it a whirl
great plugin~! I just wanted this function a few days, for my works to display better~
Dear pgarmyn,
thanks for this plug-in, its really good, but i try to do it on section elevation, but it seems won't generate the scene, is it only just for plan view??
thanks,
vd -
@vidy said:
Dear pgarmyn,
thanks,
vdIt should work in any direction. What happens? What's your system? What is your Sketchup version?
Im working with Win XP SP 2, and Google Sketchup Pro 8 M3,
it just working fine whenever im doing it at plan view (it generated the scene tab)
but when i was try to do sectionbycamera on elevation, it seems don't have any reaction.. (not generated a scene tab)thanks,
vd -
vdOK.
I found out that a section parallel to the red-blue axises doesn't work.
I will fix that. Thanks for testing vidy. -
This PLUGIN has been UPDATED :
Look at the top of this page.
IMPORTANT : erase the older version if installed (= file SectionByCam-20120506-1939.rb) -
This is my first post. And thank you for this great plugin. Its very very useful for me... Kind regards.
Me again. I am testing the plugin but having difficulties with renderer maxwell fire. It seems its not working. Any help?. Thanks.
Can't help that. Pbacot had the same experience (see above). I menshioned it in the description.
Does this plugin work with SU 2014 and btw where is the plugin folder in SU 2014?
Tested it... and it works like charm
thank you pgarmyn for the update..regards,
vd -
Sorry doesn't work yet on SU 2014
@pgarmyn:
From your first post- as edited: "Works with SKetchup 8 and 2014. NOT FOR Sketchup 2014 "
This looks like a great plugin and would be very useful for my workflow. When will it be updated for Sketchup 2016? Thanks.
