    SketchupExtension in a single file
    13 Posts 3 Posters 2.8k Views 3 Watching
      @dan rathbun said:
      But if the attempt is made sometime later, (via a change in the Preferences>Extensions dialog checkbox,) it should fail, during that particular Sketchup session. (The default @load_on_start in the registry will be set true, however, and then it will work, on the next Sketchup restart.)
      Ah! I was testing by loading an external file - using load. So my initial load didn't use Sketchup::require. Seems that I need to pop the entry off the stack after registering the extension. Nice catch.
        @dan rathbun said:
        Add to that the Sketchup.register_extension method code was changed on the C side for 8.0M2 ...
        What was that?
        • Dan RathbunD Offline
          Dan Rathbun
          @thomthom said:
          What was that?
          To much to explain.. you'll need to read the comments in the code. Scott marks what were the private callbacks from the C side.
          But basically calling the method more than once in previous version has no benefit, screwed up the extension list in the dialog.
          Now 8.0M2+, the method was changed to expect to be called more than once, and to do things, based upon the change in arg 2.
          I'm not here much anymore.
            Dan Rathbun
            One reason I am a bit adverse to this idea is, that I was hoping for a day when plugins resided within their author's filespaces, and the plugins directory had nothing but extension registration scripts. All code for actual functionality, would be in subfolders.
            I like the idea, of being able, to switch off whole groups of plugins, by author is one way.
              Jim
              The @extension_registered variable is always false when SketchUp starts, so the menus will never be created after the first time the extension is enabled.
                Thought I'd fixed that... 😳
                  Jim
                  Oh, I was just reading your blog and copy/pasted the code, but I never got the menu to appear. But then later I thought the code should work because SketchUp should go ahead and reload the file as an extension after initially registering. So not sure what's going on.
                    Dan Rathbun
                    Re-read my earlier post: http://forums.sketchucation.com/viewtopic.php?f=180&t=43200&#p384925
                    Your setting up a vicious circle.
                      Dan Rathbun
                      What about using a begin ... rescue ... end block to "fool" SketchUp.
                      Meaning set the path to a file that does NOT exist, which will raise a LoadError Exception.
                      (EDIT: ..and I think you can just use an empty string for path, in this case.)
                      begin
                        # set up here
                        plugin = SketchupExtension.new('Nifty Plugin','dummy')
                        # set other attributes
                        Sketchup.register_extension(plugin,true)
                        # if it attempts to load, the rescue block fires
                      rescue LoadError
                        # A little code for a "quickie" Plugin here.
                        Dan Rathbun
                        NO (the above,) will not work because Sketchup::require() and Sketchup::load() do not raise LoadError. They just return false on failure, and 0 on success.
                        (I do have a API bug report filed on this.)
                          They don't raise LoadError ...? That's interesting.
                          My mistake was that I tested the whole thing by loading manually from an external location instead of placing the file in the Plugins folder and having it load at startup. My "simulation" was incorrect.
