Split level concept house
This was an exercise in post work. modelled in SU, I the took a basic render from kerkythea and added the trees, sky, drive, and grass in GIMP. hard work and lots of tweaking!
Looks good. Two comments: 1) looks a little too hazy, out of focus, and 2) on the right, the straight angled lines where the building meets the grade do not look natural.
Thank you... two very good points. The first is easily tweakable in gimp, the second might have to be a bit of hand painting, as it were. Although I was intending to add a bit more greenery, planting along the walls etc, so that might be the best idea.
Mottle the light hitting the driveway. Like light filtering down through tree branches Add some foreground framing.
great idea... I shall try that
