    Rotation about the origin
    6 Posts 4 Posters 548 Views 4 Watching
      rossthompson
      Hi guys,
      I am trying to write a script that very simply rotates selected objects by 90 degrees in the Z axis. I have put together some code but it isn't working. Can anyone help? I am new to Ruby so I have probably made some really basic mistakes.
      Ross
      require 'sketchup.rb'
      # Add a menu item
      UI.menu("PlugIns").add_item("rotate90") {
        rotate90	# Call method.
      def rotate90
      	rv = Geom;;Vector3d.new(0,0,1)
      	ra = 90.degrees
      	rp = Geom;;Point3d.new(0,0,0)
      	Sketchup.active_model.Transformation.rotation(rp, rv, ra))
      • sdmitchS
        sdmitch
        # Add a menu item
        UI.menu("PlugIns").add_item("rotate90") { rotate90 }  # Call method.
        def rotate90
           mod = Sketchup.active_model
           ent = mod.entities
           sel = mod.selection
           ra = 90.degrees
        # define the rotation transformation
           trr = Geom;;Transformation.rotation(rp, rv, ra)
        # apply the rotation transformation to the selection
           ent.transform_entities(trr,sel.to_a)
        You were close. Use http://code.google.com/apis/sketchup/docs/index.html to help with syntax.
        http://sdmitch.blogspot.com/
          rossthompson
          Sam,
          Thanks very much that works perfectly.
          Ross
          • bigstickB
            bigstick
            Are you planning to build on your programming skills and add functionality to this?
            What I have always found really frustrating is when you use the group/component 'handles' to rotate components. It is a neat time-saver, but for years I have always wanted to rotate about a component's origin.
            Alternatively if anyone else out there has a plugin that does this, I would be grateful if someone could please point me in its direction.
            • sdmitchS
              sdmitch
              Check out Rotate&Scale on my blog. It works with groups and components and rotation is about the origin.
              • daikuD
                daiku
                This already exists here:
                http://rhin.crai.archi.fr/rld/plugin_details.php?id=345
                and here:
                404 Not Found
                (forums.sketchucation.com)
                Perfect for mapping to a shortcut key.
                Clark Bremer
                http://www.northernlightstimberframing.com
