Rotation about the origin
Hi guys,
I am trying to write a script that very simply rotates selected objects by 90 degrees in the Z axis. I have put together some code but it isn't working. Can anyone help? I am new to Ruby so I have probably made some really basic mistakes.
Ross
require 'sketchup.rb' # Add a menu item UI.menu("PlugIns").add_item("rotate90") { rotate90 # Call method. } def rotate90 rv = Geom;;Vector3d.new(0,0,1) ra = 90.degrees rp = Geom;;Point3d.new(0,0,0) Sketchup.active_model.Transformation.rotation(rp, rv, ra)) end -
require 'sketchup.rb' # Add a menu item UI.menu("PlugIns").add_item("rotate90") { rotate90 } # Call method. def rotate90 mod = Sketchup.active_model ent = mod.entities sel = mod.selection rv = Geom;;Vector3d.new(0,0,1) ra = 90.degrees rp = Geom;;Point3d.new(0,0,0) # define the rotation transformation trr = Geom;;Transformation.rotation(rp, rv, ra) # apply the rotation transformation to the selection ent.transform_entities(trr,sel.to_a) endYou were close. Use http://code.google.com/apis/sketchup/docs/index.html to help with syntax.
Sam,
Thanks very much that works perfectly.
Ross
Are you planning to build on your programming skills and add functionality to this?
What I have always found really frustrating is when you use the group/component 'handles' to rotate components. It is a neat time-saver, but for years I have always wanted to rotate about a component's origin.
Alternatively if anyone else out there has a plugin that does this, I would be grateful if someone could please point me in its direction.
Check out Rotate&Scale on my blog. It works with groups and components and rotation is about the origin.
This already exists here:
http://rhin.crai.archi.fr/rld/plugin_details.php?id=345
and here:
http://forums.sketchucation.com/viewtopic.php?f=323&t=9739&hilit=rot90
Perfect for mapping to a shortcut key.
