    Computer paintings
    25 Posts 2 Posters 3.3k Views 2 Watching
    • brookefoxB
      brookefox
      I will reread your first post. Other than that, I am not sure what you are saying. The pic you show is my pic, so that yes is my setup. 'Arborescence' I assume means tree (directory, folder) structure.
      My OS is Vista 64.
      ~ Brooke
        Yes πŸ˜‰
        No !
        it's that you must see πŸ˜‰ (I have made a photomontage)
        In yours above I don't see the black icon "taboure512.pde" under the "data"
          If I good remember πŸ˜‰
          the first time launch a Processing session
          Copy inside the lines above
          Save it in a folder anywhere of your choice say "my Processing test" (name of the folder)
          with the name that you want say "test" (name of your prog)
          Surrely a message eroor because ther is not yet an image inside the data folder created
          QUIT
          You must obtain a file "test.pde" and a folder "data" both inside "my Processing test" folder
          (".pde" is the extension name of a Processing program normally it's given automatically)
          (maybe extension 's file ".pde" is not visible following your system regulates )
          You must have the image follow
          You can now put inside your image inside the "data" folder created
          with the same name than inside the prog : say "sketch.png"
          (use always PNG format : support of the transparent background)
          Inside the prog the "" must be writed around the sketchUp's image!
          PImage pilou = loadImage("sketch.png");
          Relaunch it by double click on the file name "test.pde" inside your folder
          After 3 seconds (more or less following the age of your computer: mine is ten years! )
          An artistic image must be created on your screen πŸ˜„
          Grab it and past it inside your favorite 2D prog
          You can modify some numeric parameters inside the prog
          You can change of course the name of the image inside the prog
          if you input an other image with another name inside the data folder!
          (don't change the "pilou" words except you well understand the syntax)
          If you don't want the "filter Invert" on your image
          Jut put // before
          //filter(INVERT);
          The image must have always 1024*512 inside the data folder!
          Hope this help you πŸ˜‰
            And sorry it's the second post that you must maybe re-read πŸ˜‰
            • brookefoxB
              brookefox
              OK. I did not show what was beside data, only what was in data. It is beside as you advise.
              ~ Brooke
                Hum hum
                Last chance
                Copy the folder taboure512 on the Desk and run it from the Desk but I doubt
                Have you load and run some processing examples ?
                does they work ?
                  Try to launch my own one!
                  sketch_jun07a.zip
                    I use it all days πŸ˜‰
                    Model by m-dynamics
                    • brookefoxB
                      brookefox
                      Now I must figure out what is my problem.
                      Merci, Pilou, for your patience.
                      LATER THAT SAME DAY:
                      The database file thumbs.db is new, and apparently important.
                      I made a new folder and substituted my image for yours, but renamed things so the exe. and db would apply if need be.
                      It seems essential; how, where and when is the db file created?
                      β˜€
                      ~ Brooke
                        Cool so now you will can change some parameters inside the little prog itself for have some variations! β˜€
                        Have happy processing! 😎
                        For the rest, the db file, that is out of my competence! 😳
                        • brookefoxB
                          brookefox
                          Mine, too. Where's the crowd, anyway? I really don't want to have to work at this. But you do some nice things with it, so...
                          Cheers.
                          ~ Brooke
                            Yes only with these few lines, variation of the parameters, operators (*, +,/) etc...
                            and the PNG start image, you have an infinite wold to explore! β˜€
                            • 2 / 2
