    [REQ] Edge 2 Groove
    68 Posts 11 Posters 11.2k Views 11 Watching
    • pbacotP
      Thanks Sam. DL'd. Can't wait to see how it works! Peter
      • pbacotP
        Woops. Crashes SU on my Mac. Peter. No messages to report.
        • EarthMoverE
          EarthMover
          Works great on the example I provided which are created via "curves" where some of the edges are supporting non planar faces. 👍 However, it curiously fails on edges which support planar or perpendicular surfaces. Also fails on the shape I provided when the bottom is added to make it solid.
          Thanks for the work so far. I wonder can the tool be further tweaked to work on a variety of different situations where grooves would be needed? (i.e. single face grooves, grooves to define cabinet drawers, grooves for concrete building facades, etc.) Thus being more useful for a variety of different users. Also, can the width and depth be defined separately?
          Thanks again Sam for solving the first part of the riddle. What was the logic you ended up using for the code? I tried to decipher it, but it's a little over my head.
          Content Creator at Skapeup
            this only works if the selected edges are all coplanar; 'skewed' grooves will not work.
            Have you an example of that ?
            I will try the new SAM plug 😄
            • charly2008C
              charly2008
              I have tested the groove tool. The results are unusual. I do not know why.
              Charly
              • sdmitchS
                sdmitch
                Using the Edge 2 Groove model supplied, I have been able to create a plugin for this unique situation.
                [flash=800,600:14uqb6r8]http://www.youtube.com/v/JvROg-dN2YA[/flash:14uqb6r8]
                http://sdmitch.blogspot.com/
                • sdmitchS
                  sdmitch
                  Charly, Please see my last post. I knew it was a mistake to post the alpha version because people always think that, no matter what bazaar situation they can create, the plugin should be able to handle it.
                  • sdmitchS
                    sdmitch
                    Yes I'm sure much more can be done but, as I stated in the post, the plugin attached was developed and tested on that one example alone.
                    I just looked at it as a sidewalk, with at flat top and curved sides. I examined each edge to see if it was between coplanar faces, normals parallel, to indicate it was on top and calculated the boundary points of the three faces that I could pushpull to create the top and side grooves. In addition to the normals parallel, I need to require the the normal.z is pointing up or down. This will allow sides to be straight as well.
                    Adding grooves to a four sided column poses the additional problem of trying to determine "which" way is up".
                    • EarthMoverE
                      EarthMover
                      This makes sense. Thanks for posting the Alpha version. It is a very promising start. I definitely understand it was adapted to a specific situation. Hopefully it will continue to evolve into a more universal solution! 😄 Thanks again.
                      • sdmitchS
                        sdmitch
                        @earthmover said:
                        single face grooves, grooves to define cabinet drawers, grooves for concrete building facades.
                        Please provide an example of each.
                          @ Charly : for the moment you must don't take solides volumes, only open surfaces as the first example shown 😄
                          • EarthMoverE
                            EarthMover
                            I certainly will Sam. I have a bunch of billable work to finish up with at them moment, but will get you some test models as soon as I'm done. Unless someone else has time.
                            C'mon people.....get your grooooove on! 😄
                            • mitcorbM
                              mitcorb
                              @sdmitch:
                              Regarding the column and up/down question, could you relate the action to a centroidal axis about which the grooving happens? Just throwing out ideas. It might work for any linear form. Define the line, series of segments, curve as the axis, precursor to the process?
                              Vaguely related to Lines2Tubes or Tube Along Path.
                              • sdmitchS
                                sdmitch
                                mit, That is a certainly a possibility and using followme instead of pushpull. The problem will always be sorting out which edges should be followed unless the paths are selected one at a time.
                                • pbacotP
                                  uploading a cabinet example. Grooves are very small. Thanks! P
                                  (I for one have NO billable time today 😞 )
                                  cabinet with grooves.skp
                                  • mitcorbM
                                    mitcorb
                                    Hi, sdmitch:
                                    I didn't necessarily mean you would use a followme function. More like the centroidal path being continuous through the core of the linear construction, but used as a reference axis at the interfaces of the units from which a groove offset is determined for each brick, tile, stone, whatever, and then some kind of process that shrinks the offset. Alternatively a Dynamic Component is developed with abilities to skew faces, tegularize, or rebate edges?
                                    • EarthMoverE
                                      EarthMover
                                      Hey Sam, here are a bunch of different groove scenarios, which all fail with the current plugin, some causing crashes. Thanks again.
                                      Groove Maker Scenerios.skp
                                      • sdmitchS
                                        sdmitch
                                        I'm not surprised that the plugin fails and/or splats on these examples. It is going to be very tough if not impossible to come up with a general solution.
                                        • EarthMoverE
                                          EarthMover
                                          I suspected as much. A general solution would spend more time inspecting than processing I suppose. Grooves on a single (non-extruded) face should be quite simple, but I imagine the code would vary from solving the edges that turn corners. Edges that support co-planar faces and turn corners is a different procedure than those that turn corners and support non-planar. Also edges that form a "C" as opposed to closed loop would be processed different as well. Could there possibly be a prompt to help the script identify the situation before the process runs? It appears there is an overwhelming desire and need for the (universal) script, across many different industries, but I certainly understand the nature of edges in sketchup and the inability to identify them as they have no "normals" like faces do. I'm however, still hopeful for a solution.
                                          • 3 / 4
