    How to Map Rattan Furniture
    12 Posts 6 Posters 2.9k Views 6 Watching
      Jonavery16
      This is as close as I know how to get it. It isn't really correct, because the texture maps to each face individually it breaks up the pattern into little triangular shapes.
        Jonavery16
        Close up of rattan chair.JPGClose up of the face textures.
        • soloS
          There is no magic solution....yet.
          You can export to a 3rd party app and unwrap then UV map or you can cut the mesh and map on planes, or you can wait a little for a plugin that's in the works.
          Here is what I came up with using one click, I cannot discuss the plugin yet but as you can see it did a fairly decent job without needing to go to a third party app.
          There are some issues, but that's understandable considering the mesh, the plugin had to make make assumptions and it did, so it's not perfect. Personally on something like this I'd model some ribs (supports) hence dividing the mesh which would make it a lot easier to map.
          http://img607.imageshack.us/img607/276/mappedchairr.png
          mapped chair.skp
          • V
            Vicspa
            Hi Solo, when do you foresee this plugin coming out?
            • N
              ninopiamonte
              Thanks everyone for helping, especially for solo.
              And okay, I'll wait for that!!!
              πŸŽ‰ πŸŽ‰ πŸŽ‰
              • N
                ninopiamonte
                Btw, I love your used texture. That it's not in my pack.. πŸ˜„
                • soloS
                  That texture is a free Thea material for licensed users.
                  • GaieusG
                    You can reload it with your own material and UV maps should be maintained.
                    @Pete: nice job! πŸ‘
                    @Victor: I guess soon... πŸ˜’
                    • N
                      ninopiamonte
                      Ah.. What I have done is that I updated the model to a sleek one.
                      And the problem is Another uv mapping should be done πŸ˜•
                      So guys, can you help me again? πŸ˜›
                      • N
                        ninopiamonte
                        Rattanism.skp
                        • EarthMoverE
                          EarthMover
                          Wow Pete, that looks great. Nice tease on the plugin. Artisan 2 perhaps?
                          Here's a quick UV mapping with the last model. Quick export of half the chair via Whaat's UV Tools, into 3ds Max. Converted to Edit Poly, Ran Unwrap UVW modifier. Selected all faces, ran a pelt map procedure followed by a relax by face angles. Back into Sketchup via UV Tools gateway. Still a bum seam down the middle, but if cushions are added, it's a non-issue.
                          WickerPeltMap.skp
                          Content Creator at Skapeup
