    πŸ«› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    How to Map Rattan Furniture
    12 Posts 6 Posters 2.2k Views 6 Watching
    • N Offline
      ninopiamonte
      Can someone help me how to map this furniture with rattan texture?
      I have several textures, but I'm not yet practiced with uvmapping.
      So here the sketchup file and the textures. Advance thank you!
      FT.skp
      Rattan.rar
        Jonavery16
        This is as close as I know how to get it. It isn't really correct, because the texture maps to each face individually it breaks up the pattern into little triangular shapes.
          Jonavery16
          Close up of rattan chair.JPGClose up of the face textures.
          • soloS Offline
            There is no magic solution....yet.
            You can export to a 3rd party app and unwrap then UV map or you can cut the mesh and map on planes, or you can wait a little for a plugin that's in the works.
            Here is what I came up with using one click, I cannot discuss the plugin yet but as you can see it did a fairly decent job without needing to go to a third party app.
            There are some issues, but that's understandable considering the mesh, the plugin had to make make assumptions and it did, so it's not perfect. Personally on something like this I'd model some ribs (supports) hence dividing the mesh which would make it a lot easier to map.
            http://img607.imageshack.us/img607/276/mappedchairr.png
            mapped chair.skp
            • V Offline
              Vicspa
              Hi Solo, when do you foresee this plugin coming out?
              • N Offline
                ninopiamonte
                Thanks everyone for helping, especially for solo.
                And okay, I'll wait for that!!!
                πŸŽ‰ πŸŽ‰ πŸŽ‰
                • N Offline
                  ninopiamonte
                  Btw, I love your used texture. That it's not in my pack.. πŸ˜„
                  • soloS Offline
                    That texture is a free Thea material for licensed users.
                      You can reload it with your own material and UV maps should be maintained.
                      @Pete: nice job! πŸ‘
                      @Victor: I guess soon... πŸ˜’
                      • N Offline
                        ninopiamonte
                        Ah.. What I have done is that I updated the model to a sleek one.
                        And the problem is Another uv mapping should be done πŸ˜•
                        So guys, can you help me again? πŸ˜›
                        • N Offline
                          ninopiamonte
                          Rattanism.skp
                          • EarthMoverE Offline
                            EarthMover
                            Wow Pete, that looks great. Nice tease on the plugin. Artisan 2 perhaps?
                            Here's a quick UV mapping with the last model. Quick export of half the chair via Whaat's UV Tools, into 3ds Max. Converted to Edit Poly, Ran Unwrap UVW modifier. Selected all faces, ran a pelt map procedure followed by a relax by face angles. Back into Sketchup via UV Tools gateway. Still a bum seam down the middle, but if cushions are added, it's a non-issue.
                            WickerPeltMap.skp
                            Content Creator at Skapeup
