    Boolean: how do I 'outershell' multiple groups/components?
    12 Posts 3 Posters 1.7k Views 3 Watching
    • liquid98L
      liquid98
      Hi Dan,
      Thanx for your input. Used to post my questions in the 'plugins' section, my apologies for that.
      First thanx for pointing me out, the code snippet section was totally new for me, so that's a good one!
      I realize I was to quick posting my code. Indeed, the iteration range was not ok. The tree tests (right class?,
      manifold? and pro) aren't relevant in my situation.
      @dan rathbun said:
      Secondly, you must make an Array copy, of the entities (or any C++ collection,) if you will be making model changes during the iteration.
      This is the part I don't get. You say TIG wrote a lot about this subject..
      I'will look for it then, and come back here if I still don't get it.
      Thank you!
      Things that flourish fall into decay. This is not-Tao, And what is not-Tao soon ends ~ Lao tse
      • Dan RathbunD
        Dan Rathbun
        @liquid98 said:
        The tree tests (right class?, manifold? and pro) aren't relevant in my situation.
        Yes they are.. you just do not realize it yet.
        You cannot call outer_shell() or manifold? on an entity, unless it is either a Sketchup::Group or Sketchup::ComponentInstance instance object.
        IF you call outer_shell() when Sketchup.is_pro? is false (Free edition,) an Error will be raised.
        Because when changes are made to the model on the C++ side, the objects in the C++ collections are shuffled around. Your iterator will "lose it's way," and miss processing some entities, and process others multiple times.
        So use the to_a method, to make an Array, of ONLY the groups in the C++ collection, like this:
        grps = []
        model.entities.to_a.each {|ent|
          grps << ent if ent.is_a?(Sketchup;;Group)
        Or use the find_all method (which always returns an array.):
        grps = model.entities.find_all {|ent| ent.is_a?(Sketchup;;Group) }
        Then you can safely iterate using the members of the grps array (and when the entities collection rehashes itself, it will not effect your iteration.)
        unless grps.empty?
          grps.each {|grp|
            # process each group, one at a time
        I'm not here much anymore.
        • liquid98L
          liquid98
          Hi Dan,
          I do realize that. But the script I'm writing is for internal use. So everything
          this script will process meets the criteria already. But you couldn't know that.. 😒
          By the way ' outer_shell' is also available in free version, I think.
          The reason for adding the groups to an array is also clear to me now, otherwise the iteration process is not going well and SU could skip a few items.
          Now for the real problem:
          First I need to add all the candidates for the boolean unite operation to an array. In other words: only group-entities that intersect will be processed.
          I tried BoundingBox.intersect but it gives me false positives in cases of close
          proximity. So I've done some more reading and I ended up in the loops section of the SU API. Can the loop class help me here tot detect if groups really intersect??
          This is the only problem left, the boolean problem I solved by my self. ☀ ☀ This script unifies all intersecting groups to one solid:
          <span class="syntaxdefault">                file </span><span class="syntaxkeyword">=</span><span class="syntaxstring">"D;\\Desktop\\bool.skp"<br /></span><span class="syntaxdefault">            Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">open_file</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">file</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">            <br />            model </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />            entities </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities <br />            <br />            foo</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> nonfoo </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[],</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[]<br /></span><span class="syntaxdefault">            grps </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">find_all </span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">ent</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Group</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">            <br />            grps</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">a</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> unless a </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> grps</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">last <br />                            a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">name </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">'foo'</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">;</span><span class="syntaxdefault"> foo</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">push a<br />                        else<br />                            a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">name </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">'nonfoo'</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">;</span><span class="syntaxdefault"> nonfoo</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">push a<br />                        end <br />                        </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">            <br />            until foo</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> nil<br />                foo</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each     </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">ff</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> <br />                                if  </span><span class="syntaxkeyword">((</span><span class="syntaxdefault">ff</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">bounds</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">intersect</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">nonfoo</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">bounds</span><span class="syntaxkeyword">)).empty?</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> false<br />                                    </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">ff</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">outer_shell</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">nonfoo</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">])).</span><span class="syntaxdefault">name </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">'nonfoo'<br /></span><span class="syntaxdefault">                                end<br />                                 <br />                        </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">                foo </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">find_all </span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">ent</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">name </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> </span><span class="syntaxstring">'foo'</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}</span><span class="syntaxdefault">    <br />                nonfoo </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">find_all </span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">ent</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">name </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> </span><span class="syntaxstring">'nonfoo'</span><span class="syntaxkeyword">}</span><span class="syntaxdefault">     <br />            end</span>
          bool.skp
          • Dan RathbunD
            Dan Rathbun
            proximity.
            BoundingBox.intersect always returns a BoundingBox object.
            From memory.. either one of these Happen:
            (1) If it really is a 3D method: (I think,) you may have to test the result for dimension. In other words if there is no intersection, the result BoundingBox would have 0 for depth, width and height.
            (2) (And I think this is the case,) it's not a 3D method, it is a planar method. (I remember Jim explaining this in another topic, some time ago.) It sort of like the "projections" of each BB are cast onto the 3 axis planes. If there is no "interference" between the cast rectangles, then we consider there not to be an intersect. It is weird and confusing, and two groups that do not even touch each other, can have "projections" that intersect.
            So anyway.. IF your groups ARE manifold solids... why not use Group.intersect instead ??
            • liquid98L
              liquid98
              Hi Dan,
              I think the Boundingbox.intersect method is not really suitable for testing whether geometry is intersecting..
              It is true that Boundingbox.intersect returns an empty boundingbox if there is no 'intersection'.
              So we can test for that, but it is not reliable..
              Furthermore the Group.intersect method is just a Boolean method, it is not intended for testing intersection of solids..
              I feel the loop class can clarify things..
                @dan rathbun said:
                If you are going to use for .. in, you must subtract 1 from the length of the array/set/collection.
                He did, because he used ... instead of .. in the Range.
                • liquid98L
                  liquid98
                  Is it smart at all to test for intersecting geometry before attempting a Boolean operation??
                  • Dan RathbunD
                    Dan Rathbun
                    Are you wishing to run this in batch-mode ??
                    As in: Pick a folder of SKP files, and open them one after the other, union the intersecting groups, save the model under a "differed" filename, ... loop until all files in directory have been "converted" ??
                    • liquid98L
                      liquid98
                      good guess! that's the plan indeed.
                      • Dan RathbunD
                        Dan Rathbun
                        I did not guess ... I can read your mind (scary music: [Oooo ooOOooo ooooo])
                        No actually, I read your sample code in the post of 17 MAR ... the first two lines you are opening a skp file, within the code.
                        In that post, you wrote:
                        Is this to be used within a commercial setting (for commercial work.) ??
