    [Plugin] Align tool 3D (bug fix)
    58 Posts 38 Posters 159.2k Views 38 Watching
      jbrfrk
      really useful.... thanks
      πŸ‘
      J=K
      • archman212A
        archman212
        fantastic..i have been looking for this one... πŸ‘
        archman212@gmail.com
        • O
          Omez
          THANK YOU! πŸ‘ πŸ‘ πŸ‘
          I even not trying it yet, but i believe its very useful... once again, Thanks! πŸ˜„
          • john2J
            john2
            couldn't understand 4m the pdf. 😞 is there any video tutorial πŸ˜’
            Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
            • Didier BurD
              Didier Bur
              Yes here: http://sketchuppluginreviews.com/2010/06/01/align-tool-google-sketchup-plugin-review-2/
              Google is your friend πŸ˜‰
              DB
              • kenK
                ken
                Didier
                Not asking anything to be changed, however it took me some time to determine that what you call the "X axis" and "Y axis" can be any particular orientation. I was always trying to determine what the "X and Y axis" were while using the plugin. Lead to much frustration.
                I always wanted to be able to get inside the plugin and change the "X" to "1" and the "Y" to "2". To me that would have been more logical to remember, I wanted the "1's" and "2's" to align with each other.
                Thank you for your contribution.
                Ken
                • Didier BurD
                  Didier Bur
                  Hi Ken,
                  You can also think that X represent the red axis, Y the green axis, just as when you locate/translate/rotate the SU axis system.
                  DB
                    raineysky
                    Ken,
                    πŸ‘
                    I really like your idea too because I'm not use to the "x,y,z" language yet. Just now getting orientated in the 3d space πŸ˜„
                    Thank You for the plugin Mr. Didier Bur.
                    • K
                      kevinbearshu
                      Thank you very mach!
                      • W
                        wodur
                        it's an impressive plugin, almost equal to the Autocad's align tool. Autocad can scale the objet as it aligns, is it possible to do that with this plugin?
                        Thanks for your work, all of you are making sketchup a very advanced tool.
                          seebe
                          Thank you so much for this tool. You have saved me so much time.
                          • Didier BurD
                            Didier Bur
                            @seebe: you're welcome
                            DB
                            • T
                              Trogluddite
                              D'oh moment for me! 😳
                              I spent so long trying to align things using the rotate/protractor tools - when all I needed to do was type "Align" into the search box and intall this super plugin!
                              Many thanks Didier, you have made my Sketchuping so much easier!
                              • B
                                bonzi_ses
                                Thank you very mauch
                                • Z
                                  ZyberCool
                                  thanks bro..
                                    redgray
                                    i like align tool just like in autocad command, thanks a lot for this tool.
                                      desunvn
                                      @didier bur said:
                                      Here is an updated version of my align tool with a bug fix (components were deformed when non orthogonal axis were clicked). User guide also added.
                                      Regards,
                                      thank for sharing
                                        rv1974
                                        Didier, could you please add 'multiple copy' and 'preserve original instance' options (may be with say CNTRL key pressed once)?
                                        P.S. I hope I post in the right topic: is it Tools\Align command?
                                        (Align, align tool, align 2D, align 3D.. I'm confused a bit).
                                        • irwanwrI
                                          irwanwr
                                          Anyone experienced groups/components axes that cannot be hidden or erased?
                                          I've this plugin for quite long. But lately just realise that axes cannot be hidden or removed from the groups/components on the screen.
                                          How should i clear those axes after aligning groups/components?
                                          Thank you.
                                          • cottyC
                                            cotty
                                            You can change the visibility of the component axes here:
                                            my SketchUp gallery
                                            • 2 / 3
