    [Plugin] Generate Ceiling Grid (Updated 27-Mar-2014)
    99 Posts 23 Posters 98.9k Views 23 Watching
      can be used with the new Tig Split tool ?
      • sdmitchS Offline
        sdmitch
        Maybe but not sure how. Splitup just sub-divides a face. This plugin acutally creates the suspended ceiling "T" rails and "L" boundaries.
        http://sdmitch.blogspot.com/
          Seems working together without any problem 😄
          (Just don't forget to enable Hidden geometry for the Split Tig plug! 😳
          Your plug has absolute measures ? Because it made just a little one grid on the little rectangle on the right!
          And not completed trimings on the other surfaces as shown on the image
          Does this normal ?
          In fact I don't know exactly what is a "Ceiling grid" 😳
          Have you a photo link of that ?
          • mitcorbM Offline
            mitcorb
            Hi, Pilou:
            If you are looking for photos, you might look at Armstrong (World Industries), a major ceiling tile and floor tile manufacturer. A ceiling grid is a suspension system to hold acoustical tiles for both decorative and acoustical control purposes. The ceiling grid is suspended by an array of wires attached to structure above. The grid also would support light fixtures designed to fit into the grid. And, as sdmitch said, the elements are inverted T shaped intersecting rails and L shaped perimeter wall members.
            • sdmitchS Offline
              sdmitch
              pilou, Just what are you trying to do?
              A ceiling grid is the metal pieces that support ceiling tiles for a suspended ceiling.
                tomot
                Nice addition! I made a similar 2d grid used for a reflected ceiling plan using AutoLSP. many years ago. One thing missing is some math.
                1. A Suspended ceiling tile installer will divide any room by the number of tiles req'd, in length and width.
                2. He or she will then divide the left over tiles/2. Meaning leftover/2 tiles will occupy all the perimeter areas of the room, the remainder of the full size tiles fill the rest of the space.
                my plugins
                tomot
                  So this ? 😄
                  http://complasta.com/images/Metal Suspended Grid.jpg
                  • mitcorbM Offline
                    mitcorb
                    Oui, Monsieur!! 😉
                      SUFractal
                      This looks like a nice little plugin, but if I'm not mistaken, I think the grid "angle" at the perimeter is generated backwards isn't it? The angles should be reversed so that the ceiling 'pad' rests on the horizontal leg of the angle. The attached image shows a corner.
                      Thanks.
                      • mitcorbM Offline
                        mitcorb
                        I have to agree with SUFractal. I have not had the opportunity to download and test it, so I didn't know. The Tees rest on the horizontal leg of the L's
                        • sdmitchS Offline
                          sdmitch
                          Thanks.
                          You are correct the perimeter pieces are backwards. It seem that it makes a difference if you are looking at the back or front side of the face. If you reverse the face, I think that will solve the problem. I need to add a statement to check the normal of the face selected to make sure whick way it is facing.
                          • guanjinG Offline
                            guanjin
                            Why did you choose the negative and positive point of view is not correct, the grid can have a smaller selection.
                              SUFractal
                              Yes, that does solve the problem sdmitch. I was clicking on a face looking down at it ... more of a 'roof' perspective than looking up at the 'ceiling'.
                              Is it possible to have the grid generated to be centered on the face in both directions, rather than have it start in one corner?
                              • sdmitchS Offline
                                sdmitch
                                juanjin, I didn't really choose the negative view. As you know when you draw a shape on the xy plane, its' face down and so that how the plugin was created and tested.
                                SUFractal, I chose starting in a corner to limit the number of partial tiles but there is no reason that the origin counldn't be in the center of the face.
                                • sdmitchS Offline
                                  sdmitch
                                  Another day, another update!
                                    SUFractal
                                    Excellent sdmitch!
                                    As you probably know, that is how grids are generally laid out (design and construction). 😄
                                    • guanjinG Offline
                                      guanjin
                                      Hallo sdmitch
                                      Freedom to change the size is too important!
                                      But still quite useful
                                      • mitcorbM Offline
                                        mitcorb
                                        Hi.
                                        Guanjin is suggesting what sounds like a Dynamic Component? Adjust the component with change in room size and the tool inserts additional tees as required, as well as stretches tees and angles. Seems pretty involved, but maybe not.
                                        • sdmitchS Offline
                                          sdmitch
                                          @guanjin said:
                                          Hallo sdmitch
                                          If you have other standard sizes you would like to use, simply add them to the code. If you don't feel capable of doing that, tell me what you would like to have as size options.
                                          • sdmitchS Offline
                                            sdmitch
                                            Yes, yet another update incorperating two suggested inhancements.
                                            • 1 / 5
