    Stop processing rest of file?
    14 Posts 3 Posters 1.1k Views 3 Watching
      Regardless of load or require being used - I try to find a method that will stop ruby from processing the rest of the file - without killing SketchUp itself.
      • Dan RathbunD
        Dan Rathbun
        In my prototype I also have a step that is only a comment at this point:
        a) Display a webdialog here so the user can download the file(s).
        b) call retry if download successful
        I'm not here much anymore.
        • Dan RathbunD
          Dan Rathbun
          So far I am trying my best to NOT touch or override either require or load themselves.
          • tbdT
            tbd
            have a separate loader.rb that checks if LIB exists and has functions required.
            if yes, require/load rest of your code, if not ...
            http://plugins.ro
            • Dan RathbunD
              Dan Rathbun
              Having to have yet ANOTHER file for each and every library or plugin package, is not what I am aiming at...
              ... besides that does not solve the idiot situation, trying to force a plugin to load, using load(), when require does not work.
              I'm not sure there is a solution to the idiot syndrome anyway. I (personally,) would not give any support, or waste any time responding, to an idiot who does not let the plugin load the way it's supposed to.
              • Dan RathbunD
                Dan Rathbun
                ThomThom, for now do something like:
                module TT_FancyUtil
                  # move require dependancy calls inside namespace
                  require('TT/TT_Lib2') rescue raise(LoadError,'TT_Lib2')
                  require('TT/TT_GUI') rescue raise(LoadError,'TT_GUI')
                  # the rest of the module's code
                # way down the bottom of the namespace block;
                rescue LoadError => e
                  case e.message
                  when 'TT_Lib2'
                    puts("LoadError; TT_Lib2 file is not present. .. blah blah blah...")
                  when 'TT_GUI'
                    puts("LoadError; TT_GUI file is not present. .. blah blah blah...")
                  else
                    puts("Error; #<#{e.class.name}; #{e.message}>")
                    puts e.backtrace
                end # module
                  Really don't want to use another file. Many of my plugins are self contained in a single file - apart from that they require TT_Lib. And I don't want to split it up just for this check.
                    Found a way:
                    <span class="syntaxdefault">require </span><span class="syntaxstring">'sketchup.rb'<br /></span><span class="syntaxdefault">begin<br />  require </span><span class="syntaxstring">'TT_Lib2/core.rb'<br /></span><span class="syntaxdefault">rescue LoadError </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> e<br />  </span><span class="syntaxcomment"># meh!<br /></span><span class="syntaxdefault">end<br /><br />module MagicPlugin<br />  </span><span class="syntaxcomment"># Voodoo<br /></span><span class="syntaxdefault">end if defined</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault"> TT</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Lib </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"> </span>
                    • Dan RathbunD
                      Dan Rathbun
                      interesting!
                      Hmm ... I see rescue modifiers do not work with require(), for some reason ?
                      You could also do (if you did not want any module defined) ...
                      require 'sketchup.rb'
                      begin
                        require 'TT_Lib2/core.rb'
                        # meh!
                      else
                        module MagicPlugin
                          # Voodoo
                      end# begin
                        What you mean? What modifiers?
                        • tbdT
                          tbd
                          statement modifiers = conditional statements onto the end of a normal statement
                          ` name = first_name + last_name rescue "John Doe"
                          John Doe # if first_name and last_name are not defined`
                          http://plugins.ro
                          • Dan RathbunD
                            Dan Rathbun
                            The conditional keywords if and unless can be used in block position:
                            [ if| unless] ( expression)
                            statements
                            or modifier position:
                            statement [ if| unless] ( expression)
                            **rescue** can also be used in modifier poistion, but ... my attempt at this:
                            require('booboo.rb') rescue nil
                            ... does NOT trap the LoadError (because LoadError < ScriptError < Exception, and rescue only traps RuntimeError and subclasses by default.)
                            For a one-liner, we must use semi-colons:
                            begin require('booboo.rb'); rescue Exception; nil; end
