    Podium V2 interior
    72 Posts 24 Posters 9.2k Views 24 Watching
    • soloS Offline
      Your last point is interesting and one I have heard and even used from time to time, render large and reduce in post editing.
      Have you tested what the time would be to render correct size with higher settings (better AA, etc) in comparison? Just wondering if there is a speed advantage or a quality advantage doing it larger.
      • StinkieS Offline
        Stinkie
        No, I haven't. AA settings are contained within Podium's render presets. I find it more convenient to render large and downsample than to open up the preset I'm using, edit it etc. Also, altering AA settings, test rendering, altering AA settings again ... can be quite time consuming, and it's a process I'm not always in the mood for.
        The next version of Podium will give more control over AA via the UI, I believe. Per material AA, or something.
        (...) Patrick Nagel 🀒 (...)
        I had to look that one up. Ew. 😲
        • bigstickB Offline
          bigstick
          @kais said:
          nice rendering but 53 mins. is too much
          now in Lumion 2 you can do it less than 53 sec
          Yeah, but the quality won't be the slightest bit comparable. I can make an omelette in around 60 seconds, but I wouldn't like to eat it!
          I've seen what Lumion does, I've seen what all the render engines can do. They all have their benefits and drawbacks. Lumion's main benefit is speed, its main drawback is quality. Yes, I'm pretty sure you'll disagree but you'll be wrong - certainly as far as Podium is concerned. πŸ˜„
          • david_hD Offline
            david_h
            Yeah .. .Pretty disgusting. that would turn your very elegant modernist expression into a cheesy bachelor pad. The only thing missing would be the hot tub and the gold medallions πŸ’š
            • soloS Offline
              Patrick Nagel is 30 years too late, it may have worked in the 80's with your Chinese themed black and white shellacked room but today it's just cheesy.
              Remember these 80's gems? 🀒
              http://27.media.tumblr.com/tumblr_lpqicoDSup1qcygcoo1_500.jpg
              Looks like his rubbish
              • StinkieS Offline
                Stinkie
                πŸ’š πŸ‘
                  congellous
                  The set up explanation was interesting and the light around the corner is the clever bit, so is there a key light behind the camera that sounds like a good idea anyway.
                  What is the QMC setting I know it's results take ages and it looks better but is there anymore tips on this, Thanks
                  • soloS Offline
                    Tom,
                    I did not want to post here as this is a Podium thread, however I posted here: http://forums.sketchucation.com/viewtopic.php?f=81&t=43169&p=386208#p386208
                    Rendered the scene with Thea bsd, then knocked out the wall and threw in some glass bricks.
                    • 2 Offline
                      2kemon
                      Do the resulting renders from a white LEM, just outside the door, and a white sketchup background differ?
                      • StinkieS Offline
                        Stinkie
                        Hm, I should do a comparison to find out.
                        • StinkieS Offline
                          Stinkie
                          Thea version (TR1). Nothing too special.
                          • StinkieS Offline
                            Stinkie
                            Rebuilt an Evermotion scene and rendered it with Podium. Needs plates and stuff.
                            • 2 Offline
                              2kemon
                              ...you're on to something here! Very cool indeed.
                              Did you compare the results with LEM's outside openings VS. just a white SU background?
                              • StinkieS Offline
                                Stinkie
                                Hm, no. Wouldn't be too different, I believe, from the second image, which is lit by Podium's physical sky. The main difference would be that you have less control over your lighting.
                                • marked001M Offline
                                  marked001
                                  you're really pushing podium to the next level here, stinkie..
                                  http://www.revision21vis.com
                                  instagram: revi21on
                                  • StinkieS Offline
                                    Stinkie
                                    Thanks, Jason. There really isn't that much to it, though.
                                    • StinkieS Offline
                                      Stinkie
                                      Mo'.
                                      • 2 / 4
