    Podium V2 interior
    72 Posts 24 Posters 12.9k Views 24 Watching
    • soloS Offline
      Tom,
      I did not want to post here as this is a Podium thread, however I posted here: http://forums.sketchucation.com/viewtopic.php?f=81&t=43169&p=386208#p386208
      Rendered the scene with Thea bsd, then knocked out the wall and threw in some glass bricks.
      • 2 Offline
        2kemon
        Do the resulting renders from a white LEM, just outside the door, and a white sketchup background differ?
        • StinkieS Offline
          Stinkie
          Hm, I should do a comparison to find out.
          • StinkieS Offline
            Stinkie
            Thea version (TR1). Nothing too special.
            • StinkieS Offline
              Stinkie
              Rebuilt an Evermotion scene and rendered it with Podium. Needs plates and stuff.
              • 2 Offline
                2kemon
                ...you're on to something here! Very cool indeed.
                Did you compare the results with LEM's outside openings VS. just a white SU background?
                • StinkieS Offline
                  Stinkie
                  Hm, no. Wouldn't be too different, I believe, from the second image, which is lit by Podium's physical sky. The main difference would be that you have less control over your lighting.
                  • marked001M Offline
                    marked001
                    you're really pushing podium to the next level here, stinkie..
                    http://www.revision21vis.com
                    instagram: revi21on
                    • StinkieS Offline
                      Stinkie
                      Thanks, Jason. There really isn't that much to it, though.
                      • StinkieS Offline
                        Stinkie
                        Mo'.
                        • 4 / 4
