    Apartment Complex WIP
    19 Posts 10 Posters 6.5k Views 10 Watching
    • marked001M
      marked001
      thanks for the dose of reality, phil...editted my posts..i knew the chances were slim of them floatin in here, but ya never know plus its not too professional.
      i didnt think of horizontal strokes.... probably should've tried it though.. i went with vertical because i was stuck on the reflection idea.... think i'm calling this done for now...client is happy..so good enough πŸ˜‰ only spent like 5 hours on it.
      http://www.revision21vis.com
      instagram: revi21on
      • P
        Phil Rader AIA
        Jason
        Have you tried horizontal stroke marks for the illustration they might counteract the perceived height of the building. The vertical stroke marks seem to over emphasize the height of the building.
        http://www.philrader.com
        • boofredlayB
          boofredlay
          Beautiful work Jason.
          • FrederikF
            Frederik
            Really NICE, Jason...! πŸ‘
            Cheers
            Kim Frederik
              mateo soletic
              Great work Jason. πŸ‘
              Concept Illustrations
              • StinkieS
                Stinkie
                Here's the ruby. (Hope I fetched the right one out of my plugins folder!!)
                Usage:
                • set your view like you'd normally do.
                • under "camera", choose "create camera". You'll see a pop-up. Choose a name for your cam ("camera 1", "camera 2", etc), then click OK.
                • right-click in the viewport. A pop-up appears. Choose "Edit Camera", then change the settings to your liking. Click OK.
                • Right-click in the viewport again. A pop-up will appear. Click "done".
                camera.rb
                • irwanwrI
                  irwanwr
                  Usage:
                  who's the plugin author, Tom? does it able to remove a camera?
                  been trying to use the batch render in KT, but when the scene was modified, SU seems to add another cam.
                  i've been looking for a plugin that might be able to edit cam position or remove any.
                  is there any?
                  thank you.
                  • StinkieS
                    Stinkie
                    I don't know who the ruby's author is.
                    You can easily remove any camera the plugin added. The way it works, is that it actually adds a camera model to your scene -you can simply delete that model. As for the camera's position, you can edit its height and tilt via the plugin, and you can quite simply use SU's native tools to move it about or rotate it.
                    Efficient, and totally WYSIWYG.
                    • DanielD
                      Daniel
                      Beautiful image, Jason. IMHO, I think it could do with some more people and cars, to convey the idea of a thriving (and prosperous) community.
                      My avatar is an anachronism.
                      • irwanwrI
                        irwanwr
                        sounds like a great script to me. i'd like to download it if you don't mind.
                        thank you πŸ‘
