    Audi r8
    30 Posts 6 Posters 2.5k Views 6 Watching
      ScottPara
      The HDRI looks nice as does the lighting. I am not sure if you did anything to the materials but they need some tweaking to really show off the ability of the render engine. The shadow is quite a bit off as well.
      Scott
      Love the fact that some HATE my avatar.....
      • F Offline
        fabiorossi
        Scott
        It's true, the materials aren't the best; the materials are that the library has by default by engine blender ;it's possible to improve them πŸ˜‰
        my blog
        http://progettin3d.blogspot.com/
        • boofredlayB Offline
          boofredlay
          Very nice result.
          • michaliszissiouM Offline
            michaliszissiou
            Very nice. Indeed. πŸ‘
            So, you're following blender development. But you didn't try cycles?
            Cycles is what you're asking and go for this. My advice.
            Now, you may think that it's still alpha and you can't combine a hdri this way. It's possible though. Have a look here.
            http://visfxblender.wordpress.com/2011/12/26/project-6-beep-boop-bop-a-love-story/
            A very nice animation/test and an excellent video tut.
            cheers.
            BTW if you're facing problems on how to export SKP to blender, please fill free to ask me.
            • F Offline
              fabiorossi
              cheers.
              Yes I know the potential of cycles which is essentially a rendering in real time; blender currently has some of the most powerful rendering engines including internal engine implemented especially in the speed; so it isn't a real time but it's possible to try different settings in a short time
              my blog
                michaliszissiou
                Not exactly. Developers of cycles are sitting on a goldmine software. Cycles is a real time preview renderer but it's also a physically correct engine (essential for animation). On extreme settings is not fast either. But can handle cuda (GPU) and is fast enough. Much faster than kerky based solutions.
                Blender internal isn't fast at all, neither supports GI. Not good for archi vis, maybe some exteriors and still not great.
                BTW shinny materials in cycles are superior. The best around.
                • F Offline
                  fabiorossi
                  hdri lighting up
                  my blog
                  • F Offline
                    fabiorossi
                    I fully agree with you, however, perhaps because cycles is still in alpha release, I haven't seen impressive archiviz examples around the net.Do you know some goods examples to show me?
                    my blog
                      michaliszissiou
                      Something like this?
                      http://blenderartists.org/forum/attachment.php?attachmentid=159702&d=1320515852
                      It was some fast render, just experimental.
                      I can't search for what you're asking now, there lot of fine examples. Not possible for blender internal engine anyway.
                      Neither your car image is archivis scene so, here's mine, using cycles.
                      http://dl.dropbox.com/u/24090090/Vol3Nep.jpg
                      But my question is this.
                      Do we have a decent way to export SU projects to blender? With textures or without them.
                      I know much about it but 'decent' means something else πŸ˜†
                      • F Offline
                        fabiorossi
                        the sense of this post is not to wish to demonstrate that the internal blender render engine is better than cycles ;on the contrary, just because I know the enormous potential of the cycles I wanted to test the good old internal engine blender for fun.
                        with regard to decent export from SketchUp,I have always exported obj format model textured without problems
                        my blog
                          michaliszissiou
                          Exporting using what?
                          1. you own the pro version
                          2. you use the free ruby obj exporter.
                          3. a third party on line method.
                          In any case vertices aren't welded. You can't apply smoothing.
                          • F Offline
                            fabiorossi
                            I use free ruby obj exporter and I can smooth the geometry!......sometimes I get the impression that we are talking about different software.... πŸ˜„
                            my blog
                              michaliszissiou
                              In blender/edit mode/select all[A]/[W] menu/remove doubles. How many removed? this welds these vertices.
                              No, we're not talking about different software. The whole community noticed this. SU exports non welder vertices.
                              • F Offline
                                fabiorossi
                                scottpara,
                                thanks for the advice and compliments for the works, but there is a fundamental difference between showcases and cycles: you buy the first but the second .....................is freeeeeeeeeeeee!!
                                my blog
                                  ScottPara
                                  Understood although free does not always equate to best. I was just trying to show a low cost ($995) solution for great quality rendering with a built in real time solution that works.
                                  • F Offline
                                    fabiorossi
                                    Scott believe me, no one doubts about the ability to Showcase but if you take a look around the net to looking for cycles tutorials you will be amazed!
                                    my blog
                                      ScottPara
                                      Does cycles offer a real time solution?
                                      Things I REALLY like about showcase:
                                      Alternatives (huge feature)
                                      Behaviors (accepts rigging from Maya)
                                      Real time rendering (done right).
                                      • F Offline
                                        fabiorossi
                                        just yesterday I discovered this feature of cycles ......
                                        http://www.youtube.com/watch?v=b6Wm4r_FsrU&feature=player_embedded
                                        my blog
                                          michaliszissiou
                                          Cycles is a modern render engine, a 2011 development. It still is alpha. Not all futures there, but I love it already.
                                          You have to wait a few more months, yes development of blender is fast.
                                          This last video doesn't show much. Yes, coordinates/windows projection, this probably goes for reflections.
                                          You have to see and understand the superb nodes system to understand.
                                          Here's a link to a small tut of me, in sculptris forum but shows what window projection means for textures. Nothing fancy but bumps are superb in cycles. We're going for micro displacements BTW, soon.
                                          http://www.zbrushcentral.com/showthread.php?143454-My-beta-testing-doodles&p=917407&viewfull=1#post917407
                                            sepo
                                            Scott... Did you use Showcase or Showcase pro?
