    Moving object in steps
    6 Posts 3 Posters 299 Views 3 Watching
      Pout
      Let's say if first move an object (by translation) by 3 according to the z-axis (so 3 metres higher)
      Later on I want to move it to 5. In a translation that would be a move of 2
      Is it possible to set the position in z instead of doing translations?
      Or can i reset/remove the previous translation and do a new translation?
      Hope this makes sense.
      Regards
        Pout
        some extra info:
        it's a section plane i try to move
          Is all done in one operation?
          "object" - you mean any Entity or a Group or ComponentInstance? With Groups and ComponentInstances you can get and set the transformation matrix, .transformation and .transformation= where you could manipulate the Z position if you like.
          • Chris FullmerC Offline
            You're transforming it with transform_by_vector, right?
              Pout
              Thomthom, different operations
              So there can be other commands in between.
              With the object I mean a section plane
              So I'll need to use transform_entities or transform_by_vector
                Pout
                i got it, will post solution later
