    Model's save method, about chinese filename and path
    6 Posts 2 Posters 647 Views 2 Watching
    • O Offline
      ODM
      HI,all,
      A problem, about model's save method. don't support the Chinese filename and path. It's ok for Sketchup's open_file method. such as:
      Sketchup.open_file "/Users/liuzhenyi/Desktop/中文/测试.skp"
      -> true
      model = Sketchup.active_model
      model.save "/Users/liuzhenyi/Desktop/中文/测试.skp"
      -> nil
      How does it work? Thank you!
      ODM.
      http://www.SketchUpBAR.com
        Where do you get the string from? A .rb file?
        Ruby 1.8 doesn't support Unicode characters. You might be encountering some problems related to that, that somehow the string with the path is mangled.
        http://forums.sketchucation.com/viewtopic.php?f=180&t=20657&p=205614
        • O Offline
          ODM
          Thanks thomthom.
          get string's method,see Tig's batchpurge plugin:
          model=Sketchup.active_model
          path=model.path.tr("\","/")
          then, path is "/Users/liuzhenyi/Desktop/中文/测试.skp" (use mac ox system).
          I will try it use UnicodeEX module, thanks again.
            That might be your problem right there, you manipulate a Unicode string with Ruby. That might very well mess up the string.
            ( Sidenote: instead of
            path=model.path.tr("\\","/")
            make use of the File class to correct the path for you if needed.
            path=File.expand_path( model.path )
            http://www.ruby-doc.org/core-1.8.6/File.html#method-c-expand_path )
            But if you are dealing with Unicode characters, avoid manipulating the strings.
            • O Offline
              ODM
              path=model.path
              path1=File.expand_path(model.path)
              path2=model.path.tr("\\","/")
              path.class #-> string
              path1.class #-> string
              path2.class #-> string
              path,path1 and path2, all class are string, all value are "/Users/liuzhenyi/Desktop/中文/测试.skp"
              Whether it can be said path=path1=path2.
              model.save method see:
              http://code.google.com/intl/en/apis/sketchup/docs/ourdoc/model.html#save
              Should be filename is string, use path "/Users/liuzhenyi/Desktop/en/en.skp" ,it's ok.
              Should make the save method, recognized the chinese filename and path.
              unicode can solve? or rewrite the save method. SketchUp 8.0 Ruby version is 1.8.6,maybe sketch up 9.0 will support....
              thomthom,Thanks a lot .
              • O Offline
                ODM
                I would like to support chinese path as Sketchup's open_file method, model's save method why not support it?
