    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    Question - Continuous Orbit, Pan and Zoom.
    5 Posts 4 Posters 814 Views 4 Watching
      jaceguay
      With ruby, it is possible to make a Continuous Orbit command? Like holding the mouse button, and have the effect of the mouse wrap around screen edges to orbit the model continuously, without having to click again with the mouse button. And can the same be done with zoom an pan?
      I tried to make a autohotkey script but as soon as the mouse cursor wrap arround one screen edge to another the mouse position change and the orbit jumps to the initial angle.
      • Chris FullmerC Offline
        No, I don't think such a thing is possible in Ruby. Maaybe someone whose a lot smarter than myself could hack something together using some special windows hacking, but I'm not convinced that is even possible.
          jaceguay
          After some research I think the same, in blender this behavior is build in and the cursor is wrap around the view port, I think it can“t be done in ruby except with the help of some external program maybe. Thank you for your response.
          • PixeroP Offline
            Pixero
            It can be done. At least continuos rotation.
            The cursor won't wrap to the other side of the screen but rotation continues "beyond the screen edges".
            I have it working in a internal script of mine. Can't post the whole thing but here are some code snippets of the core part:
            #Snippets, not a full script
            def curve(new, old, increments)
            	if (increments == 0)
            		return(new)
            	@diff = (old-new)
            	@sign = sgn(@diff)
            	@slip = (@diff)/increments
            	old -= @slip
            	if(@sign != sgn(@diff))
            		return(new)
            	return(old)
            end#
            def sgn(x)
            	if (x < 0)
            		x = -1.to_i
            	if (x = 0)
            		x = 0.to_i
            	if (x > 0)
            		x = 1.to_i
            	return(x)
            end#sgn
            def update
            	#Camera look
            	@dx = curve(@mouseX-@lastx, @dx, 1)
            	@dy = curve(@mouseY-@lasty, @dy, 1)
            	@dx *= 0.005 #Pan speed
            	@dy *= 0.005 #Tilt speed
            	pan = Geom;;Transformation.rotation @eye, @worldUp, -@dx.degrees
            	tilt = Geom;;Transformation.rotation @eye, @xaxis, -@dy.degrees
            	new_target = @target.transform! pan
            	new_target = new_target.transform! tilt
            	pan = [0,0,0] #Resetting the pan values
            	tilt = [0,0,0] #Resetting the tilt values
            	target = new_target
                   #Transform camera
            	@camera.set(@eye, target, @worldUp)
            end#update
            def onMouseMove(flags, x, y, view)
            	@mouseX = x
            	@mouseY = y
            end#onMouseMove
            def onLButtonDown(flags, x, y, view)
            	@lastx = x
            	@lasty = y
            end#onLButtonDown
              DZoltan
              Hi, Pixero. I have a same problem with continous orbit. I read many post some other sketchup forums about this and just found your post now. You made this script? Can you send the fully working script? thank you and sorry for my english (i have problem with the grammar)
              Zoltan
