    Add_faces_from_mesh returns what ?
    3 Posts 2 Posters 272 Views 2 Watching
    • Didier BurD Offline
      Didier Bur
      Hi guys,
      As the API doc says, 'add_faces_from_mesh' is supposed to return an array of newly created faces, if successful.
      I always got 0 or nil as return values (like 'fill_from_mesh').
      If I want to retrieve the newly created faces, do I have to store the number of entities before an 'add_faces_from_mesh', then count the new entities.length after the 'add_faces_from_mesh' call, then iterate through these new entities to retrieve the faces ???
      Any help appreciated πŸ˜„
      DB
        Yea, the docs are wrong.
        To get the new entities:
        entities = Sketchup.active_model.active_entities cache = entities.to_a entities.add_faces_from_mesh( mesh ) new_entities = entities.to_a - cache
          Didier Bur
          Thanks ThomThom,
          Here is what I planned to do:
          nEntsBefore=Sketchup.active_model.entities.length
          Sketchup.active_model.entities.add_faces_from_mesh(m)
          nEntsAfter=Sketchup.active_model.entities.length
          arrayOfNewFaces=[]
          nEntsBefore.upto(nEntsAfter-1) { |i| next if ent=Sketchup.active_model.entities[i]; arrayOfNewFaces.push(ent) }
          Your code is mush more simple than mine πŸ˜‰
          DB
