    WIP -- 'Protrude' ruby from Jim Foltz
    49 Posts 24 Posters 29.6k Views 24 Watching
    • O
      orion1310
      kwistenbiebel peut tu m'expliquer, comment tu fait pour garder les mêmes épaisseurs entre les troues au niveau de ton plafond, dans ton rendu?
      • W
        wisnuarch
        Hallo, there,...
        I've a problem with offset,i set the number,and I run the protrude, but the result isnt offsetted, fyi: I also have install offset.rb, would you give me some enlightenment ? 😄
        http://img651.imageshack.us/img651/6607/13867939.jpg
        Uploaded with ImageShack.us
          Jim
          Hi wisnu,
          Please try to run Protrude again with the Ruby Console window open. Do any errors appear?
          • W
            wisnuarch
            Hallo, Jim
            I just try to run protrude and the ruby console output:
            {"dmax"=>["65"], "omin"=>["0"], "dmin"=>["35"], "tmin"=>["15"], "hmin"=>["1"]}
            rcvd callback: "setReasonableValues()"
            setResonableValues:
            {"dmax"=>["65"], "omin"=>["0.02m"], "dmin"=>["35"], "tmin"=>["15"], "hmin"=>["0.17m"]}
            setResonableValues:
            rcvd callback: "do_over()"
            #Sketchup::Face:0x14171f88 did not offset:
            #Sketchup::Face:0x14171f74 did not offset:
            #Sketchup::Face:0x14171f60 did not offset:
            #Sketchup::Face:0x14171f4c did not offset:
            #Sketchup::Face:0x14171f38 did not offset:
            #Sketchup::Face:0x14171f24 did not offset:
            #Sketchup::Face:0x14171f10 did not offset:
            #Sketchup::Face:0x14171efc did not offset:
            #Sketchup::Face:0x14171ee8 did not offset:
            thanks, 😄
              Jim
              Please try the latest version of offset.rb - it was updated just this week and a bug was fixed which may be related to this error.
              • W
                wisnuarch
                Thanks a lot, Jim, its work now 😍
                This plugin is awesome!!!
                  smuncky
                  Does anyone else have problems with this plugin in v2016? I understand it's an older plugin, but it does work in 2015.
                    Works like a charm inside the 2016, 2015 Make and I suppose the Pro! 😎
                    In the 2015 you can't move the Dialog Box of Parameters but you can input parameters! 🤓
                    http://s6.postimg.org/ijcd9opsh/GIF_prot.gif
                    • majidM
                      majid
                      What a great plugin for interior design... Thanks a bundle Jim!... I was missing it for a while!
                      • 3 / 3
