    WIP -- 'Protrude' ruby from Jim Foltz
    49 Posts 24 Posters 28.6k Views 24 Watching
      Jim
      @olishea said:
      Hi there.
      I installed both the protrude.rb and progressbar.rb but when i select a face and then divide, nothing happens.
      no warnings or errors, the model just stays the same.
      I have attached a picture of where I placed the rb file. I also copied the protrude folder into my plugins (not sure if this is where it should be!!)
      Hi olishea, welcome to the forums.
      I do believe this is a Mac problem, and I may be able to find a fix when there is more time. I don't have a Mac to test and it's hard to debug without one.
      • olisheaO
        olishea
        thanks jim im keen to give it a go!!
        oli
        • broomstickB
          broomstick
          Hoping a working mac version is on the way. This is one nifty little plugin!!
          • B
            bugmcw
            any news on mac-ready version!? i wanna play with it!!!
              Jim
              Would some kind and generous Mac user be able to test this version for me? 😄
              Unzip and replace all previous protrude files and folders in your Plugins directory.
              edit -
              Ok, thanks BTM. This is a new file.
              • B
                BTM
                Error Loading File protrude.rb
                no such file to load -- jf_menu
                when I take off the require 'jf_menu', the web dialog that appears when used is white and blank.
                • olisheaO
                  olishea
                  hi jim,
                  the protrude window pops up now with no warning messages.....but.....it doesn't work.
                  I take it you have to select a face then divide then protrude....but when I click divide nothings happens, I have tried entering different values too (and reversing faces)
                  oli
                  • P
                    pedromarmol
                    edit -
                    Hello!
                    I'm spanish Mac user, i works with sketchup 6, the plugin no works, when you select it in the menu of plugin, it appears a blank window and nothing more.
                    I hope your help, and thanks!
                    • mariochaM
                      mariocha
                      Same here on Mac. Selecting a face and then hitting "Divide" doesn't do anything at all.
                      Snif 😢
                      In fact, the Divide part is the one I need most since the Greeble plugins works very well.
                      Updt: Ok, been using FFD to divide.
                      %(#008000)[Mario C.
                      • O
                        orion1310
                        kwistenbiebel peut tu m'expliquer, comment tu fait pour garder les mêmes épaisseurs entre les troues au niveau de ton plafond, dans ton rendu?
                        • W
                          wisnuarch
                          Hallo, there,...
                          I've a problem with offset,i set the number,and I run the protrude, but the result isnt offsetted, fyi: I also have install offset.rb, would you give me some enlightenment ? 😄
                          http://img651.imageshack.us/img651/6607/13867939.jpg
                          Uploaded with ImageShack.us
                            Jim
                            Hi wisnu,
                            Please try to run Protrude again with the Ruby Console window open. Do any errors appear?
                            • W
                              wisnuarch
                              Hallo, Jim
                              I just try to run protrude and the ruby console output:
                              {"dmax"=>["65"], "omin"=>["0"], "dmin"=>["35"], "tmin"=>["15"], "hmin"=>["1"]}
                              rcvd callback: "setReasonableValues()"
                              setResonableValues:
                              {"dmax"=>["65"], "omin"=>["0.02m"], "dmin"=>["35"], "tmin"=>["15"], "hmin"=>["0.17m"]}
                              setResonableValues:
                              rcvd callback: "do_over()"
                              #Sketchup::Face:0x14171f88 did not offset:
                              #Sketchup::Face:0x14171f74 did not offset:
                              #Sketchup::Face:0x14171f60 did not offset:
                              #Sketchup::Face:0x14171f4c did not offset:
                              #Sketchup::Face:0x14171f38 did not offset:
                              #Sketchup::Face:0x14171f24 did not offset:
                              #Sketchup::Face:0x14171f10 did not offset:
                              #Sketchup::Face:0x14171efc did not offset:
                              #Sketchup::Face:0x14171ee8 did not offset:
                              thanks, 😄
                                Jim
                                Please try the latest version of offset.rb - it was updated just this week and a bug was fixed which may be related to this error.
                                • W
                                  wisnuarch
                                  Thanks a lot, Jim, its work now 😍
                                  This plugin is awesome!!!
                                    smuncky
                                    Does anyone else have problems with this plugin in v2016? I understand it's an older plugin, but it does work in 2015.
                                      Works like a charm inside the 2016, 2015 Make and I suppose the Pro! 😎
                                      In the 2015 you can't move the Dialog Box of Parameters but you can input parameters! 🤓
                                      http://s6.postimg.org/ijcd9opsh/GIF_prot.gif
                                      • majidM
                                        majid
                                        What a great plugin for interior design... Thanks a bundle Jim!... I was missing it for a while!
                                        • 3 / 3
