    [REQ] Intersection Behavior > Groups
    13 Posts 5 Posters 823 Views 5 Watching
    • jolranJ Offline
      jolran
      I think you would get better response if added some illustrations to this.
      Otherwise, why not use sectionplane and TIG's sectionscutplane-tool. That way you would not alter the geometry and could put the "sectioncut-geometry" in it's own layer.
      But you say you want to export. Hmm.. Sections will display then maybe.
      Edited: I mean NOT display then. Sorry.
      • gillesG Offline
        gilles
        Maybe I'm misunderstanding something but if you group your intersection it does not slice any thing before you decide it to intersect with something else?
        • JClementsJ Offline
          JClements
          When an intersection is performed, the RESULTING "insection-geometry" is NOT GROUPED. When the new "intersection-geometry" overlaps existing geometry in model which is not grouped, the existing geometry is bisected.
          If, for example, the existing geometry was a circle or arc or extrusion created by push-pull or follow-me, then it is altered (looses some of its attributes or properties); this what I don't want to have happen. That is why I was hoping that two selected overlapping groups could somehow create an intersection and secondly the resulting "intersection-geometry" be grouped afterwards.
          I can post an example if this is unclear.
            driven
            hi John
            you can use Chris's Loose2groups ruby before and after your intersection, the first will avoid the new intersections clashing with loose geometry and the second will put it in a group [being the only loose geometry left], if you asigned short cut keys to L2G and intersect it would be as fast as a ruby, which would need to do all those steps anyway...
            http://forums.sketchucation.com/viewtopic.php?f=323&t=16154#p126103
            • sdmitchS Offline
              sdmitch
              JClements, Try the attached plugin and see if it does what you are looking for.
              Grouped intesection of groups
              http://sdmitch.blogspot.com/
                JClements
                Sam, I think you nailed it.
                Thank you very much.
                This will save a lot of time both in creating grouped intersections and in enabling me to easily modify the design of the model at a later date.
                If it is not a big issue to modify the script, could the intersection groups be named, "Intersection" ?
                Attached is a quick test I did.
                Test of the Intersect Group script.skp
                • sdmitchS Offline
                  sdmitch
                  JC, I realized I hadn't named the intersection group and it has been added. Re-download plugin from previous post.
                    driven
                    Hi Sam,
                    can the group now named 'intersections' be put on a layer of the same name?
                    and is it possible for the tool to stay active until another is chosen with an option to add to the existing group or create 'intersections_02' or similar?
                    works on the mac by the way...
                    cheers again
                      JClements
                      Thanks again, Sam.
                      Hey Driven,
                      I see where you are going. I had his in mind at one time too, but with the Outliner you can now do search for "Intersection" and then move them to any layer of your choice OR (and I haven't tested this yet) change the default layer before using the script.
                      Regards
                        driven
                        @jclements said:
                        Hey Driven,
                        Outliners known to cause problems with other rubies, so I avoid it like the plague,
                        it's even easier to make layers on a mac using the 'entity info' box.
                        and I never change the default layer for the geometry just groups and components.
