    AutoCAD layout option
    5 Posts 3 Posters 448 Views 3 Watching
      rock1
      I have 5 plans in a single autocad file. I recently saw a layout option that fixes the view
      and the areas that you want to print.
      I want to do like this.
      1 layout I want to create is of an A1 size sheet on which these 4 floor plans are placed in a square fashion, i.e. each plan on one vertice of a square. I want to set the printer output option as a postscript level 2 file
      in another layout I want to put the site plan on an A1 sheet. Here I also want a postcript level 2 file.
      However in my original drawing, these plans are placed next to each other in a linear fashion.
      Is this possible?
      Signature removed by SCF Admin
        kobus
        look up viewports. It is possible to have many viewports in a layout, but explaining this on a sketchup user forum seems beside the point. I suggest you look up the Autodesk user forums and launch your search there ? good luck !
        you should be interested in the future. you will spend the rest of your life there
        • boofredlayB Offline
          boofredlay
          Sign up at the CadTutor and ask your Autocad questions there. You will get a better response.
          http://www.cadtutor.net/
            rock1
            well i already did, cadtutor gave me no answer, autodesk forums gave a confusing reply πŸ˜’
              boofredlay
              So they gave you no answer but the one you got was confusing? πŸ˜•
              Do you have a link to your question over there please? You must be registered under a different username.
