    Observers and undo question
    11 Posts 3 Posters 765 Views 3 Watching
      Doing any model changed in an observer event is like opening a can of worms. In worst case scenario you can make SU crash - which is very likely. Messing up the Undo/Redo stack is another.
      • Dan RathbunD
        Dan Rathbun
        There was a similar post perhaps last week on this subject. We noted the API warnings in that post as well.
        See: Bug Splat on erase!
        He was able to overcome his Splat! by "cheating" the undo stack (see his last post.)
        Are you wrapping your transform ?:
        begin
          model.start_operation("Brett's Xform")
          ### transform here
          model.commit_operation
        rescue Exception => e
          model.abort_operation
          puts("Error #<#{e.class.name};#{e.message}.>")
          puts(e.backtrace) if $VERBOSE
        I'm not here much anymore.
        • B
          Brett McAllister
          begin
          >   ### transform here
          > end
          No I haven't.
          I haven't used any rescue's within my coding, the example you provided,what does the backtrace $VERBOSE do?
          • B
            Brett McAllister
            It's odd, if I trigger the transformation with the tool observer no problem with undo's, redo's ,if I use the entities observer no crashes, but no undo.
            Bizarre.
            • Dan RathbunD
              Dan Rathbun
              The model edits between the model.start_operation and model.commit_operation are wrapped up into one undo operation with the given name in the menu. There are also some other optional tweeker arguments (listed as "tricky".)
              The begin .... rescue ... end block is for standard safety (highly recommended by Google,) as otherwise if an error occurs, the model could become corrupted. The model.abort_operation call in the rescue clause can "reset" the model back (so you don't have a partial group edit, or corruption.)
              P.S. See: Bug Splat on erase!
              • B
                Brett McAllister
                Sorry, misunderstood yes I wrap my operation's with model.start and model.commit
                Dan from your experience what particular sketchup methods would you recommend using the rescue clause in?, I haven't really struck to many issues with bugsplats or errors but if certain methods throw the odd fault I will insert a few.
                I had a look at the post you pointed out,the observer class I have coded is just an standard instantiated class not a tool. this observer runs in the background and reacts to other tools.
                  Scott from Google recommended using the Tool Observer to make model changes instead of Entity/Entities observers because the Tools observer is more predictable.
                  • Dan RathbunD
                    Dan Rathbun
                    Oh.. any File operations that don't automatically close the file, perhaps the SU API TextureWriter class, any Import or Exporter.
                    Maybe the LoadHandler class.
                    • Dan RathbunD
                      Dan Rathbun
                      I thot he recommended using the ModelObserver#onTransactionCommit() ??
                      At least you said that he did:
                      (http://forums.sketchucation.com/viewtopic.php?f)":1nqhthbw]Other notes
                      Another thing I learned was that doing modifications to the model on observer events can cause lots of problems.
                      •If a script is doing something which trigger an event that modifies the model it will break the undo stack. I also seem that it can make SU unstable. You could potentially cause infinite loops.
                      •After consulting with Scott it seems that queueing up a list of modifications to be done to the model and executing the list on ModelObserver.onTransactionCommit is the most reliable way to do it.
                      Although I've never seen a [ Code ] example posted (hint.. hint..)
                        It's been a bit back and forth. I think it might be a combo - depending on what you do. Even they find the topic troublesome.
