    DLL callback to ruby
    41 Posts 4 Posters 11.2k Views 4 Watching
      Alienizer
      aaaaaaaaaaah OK, now it's clear to me. I can see exactly what you mean and how this works.
      Dan, thank you so much for your time to explain all this to me. I don't know how to thank you enough, and I wish I could return the favor, but you are obviously way above me that there is nothing you can learn from me. I realy appreciate it Dan.
      Now I'm gonna go play.........
      I'm from Mars and moved to Earth to alienize you. Unfortunately, I became humanized.
        Alienizer
        Dan, one last question, can the dll be compiled in 64bit or does it have to be 32bit like SK?
        Does the handle return by rb_define_module('Sketchup') correspond to the ISkpApplication interface?
        • Dan RathbunD Offline
          Dan Rathbun
          I would say 32bit, because the Ruby that Sketchup loads is also 32bit. There is a 64bit Ruby edition, but it may be in the 1.9.x branch, which Sketchup cannot load even 1.9.x 32bit.
          I would say "not exactly". There may be some C++ methods from that interface, that are "Ruby wrapped" into the Sketchup module, as well as others from different C++ objects.
          Getting a handle on the application object (and from there it's window object, and then it's UI element objects, and so on...) are methods that the current Ruby Sketchup module lacks. You'll have to use a C++ call, as shown in the SDK examples to get the app handle.
          I'm not here much anymore.
            Alienizer
            Thank Dan. So far, everything works great, I even got this to work...
            modUI = rb_define_module('UI');
            menu = rb_funcall(modUI, rb_intern('menu'), 0, nil);
            but I'm stuck on this one...
            rb_funcall(menu, rb_intern('add_item'), 1, rb_str_new2('File/Testing'));
            It tells me "tried to create Proc object without a block"
            Where do you learn all this? I can't find any docs on rb_intern or what to pass to it. I only guess!
              Dan Rathbun
              The API add_item method takes 2 args, a String and a Block, ... not 1 arg.
                Alienizer
                Indeed! I figured it out, and the rb_intern('menu') takes one, a str of the submenu name, like "Plugins" right?
                When I do rb_intern('add_submenu') with 1 arg of str "Testing", it adds only "T" to the Pluigns menu, the first letter only!?
                If I don't use rb_str_new2 SK crash, Am I doing it right?
                For the Block, do I have to use rb_something to pass the Block, or just the reference pointer?
                Sorry to be a pain in the......
                  Dan Rathbun
                  At the bottom of the "Extending Ruby" chapter, of the "Pick-Axe" book:
                  *ID rb_intern(char name")
                  Returns an ID for a given name. If the name does not exist, a symbol table entry will be created for it.
                  I just pasted an example that used the rb_intern to create an ID... not sure if it's really needed. You can try just passing a normal string, as the method name argument.
                  (Using rb_intern on the C-side, is the same as using a Symbol on the Ruby side, thus:
                  :test_item or "test_item".intern or "test_item".to_sym
                  What are the arguments, for ruby C-side functions, generally?
                  The list at the bottom of the "Extending Ruby" chapter, is not complete, AND that edition was written for Ruby circa 1.6.x (so it's out of date.)
                  For a definitive list, refer to to the function prototypes, in the Ruby C source folder:
                  %(#000000)[**.../include/ruby-*<version>*/ruby/ruby.h**]
                  .. so if your using Ruby ver 1.8.6, the path would be:
                  %(#000000)[**.../include/ruby-1.8.6/ruby/ruby.h**]
                  ADD: .. and other header files as well.
                    Dan Rathbun
                    Yea, you need to use rb_str_new2 to convert the Cstring to a Ruby String.
                      Alienizer
                      Thanks Dan
                        Alienizer
                        Dan, what is the Block expected in rb_funcall(menu, rb_intern('add_submenu')...
                        I keep getting the error "tried to create Proc object without a block" if I use 1 arg.
                        If I use 2 arg, I get "wrong number of arguments (2 for 1)" but even you said it needs 2!? Confusing πŸ˜•
                          Dan Rathbun
                          Not sure... the proc and block functions are listed in intern.h
                          Depends on if the block / proc will be defined at runtime on the Ruby side, or before hand in your C code.
                          This generated doxygen website is old (v 1.8.4) but you may find it easier to find things:
                          http://www.ruby-doc.org/doxygen/current/globals.html#index_r
                            Alienizer
                            Thanks Dan
                              Dan Rathbun
                              @alienizer said:
                              Thanks Dan
                              no problemo ...
                              Also, if you have the Ruby Reference CHM, when you wish to see the C-side source for a method, you can click within the method's definition area, and a source box will unfold.
                                Alienizer
                                Sweet! But only ruby18-core.chm works out of the 3! Or is it me?
                                I just posted http://forums.sketchucation.com/viewtopic.php?f=180&t=39119 another challange for you πŸ˜’ 😳
                                  Dan Rathbun
                                  ruby18.chm is a wrapper that loads both of the other two, as expandable nodes in the tree control.
                                  CHM files use a MSIE stub named hh.exe
                                  They a compiled HTML Help Markup files.
                                  You can get the HTML Help Workshop app on MS Download.
                                    Alienizer
                                    Yes indeed, I didn't know the other 2 were loaded into the one. That's a nice ref book! Thanks Dan.
                                      Dan Rathbun
                                      Well it's supplied with the mingGW compiled Windows Ruby one-click install packages. So I'm not responsible.
                                      Check your Private Messages
                                        Alienizer
                                        I know, but I should have figured it out myself 😐
                                          driven
                                          why would you use
                                          Sketchup.send_action(JcB::My_Ext.initalise)
                                          when
                                          works for a loaded file?
                                            Marthmatica
                                            looks like you solved the problem.
                                            If I want to call an rb function, from a loaded rb in SU, you could just send this function from a dll:
                                            Sketchup.send_action my_rb_function_def_name_in_an_rb_loaded_file (no string wrap), as you can other SU commands
                                            which rb SU command, and its function call string is just a string in a class property or in some dll function, thus called in either direction, from dll, or to dll.
                                            Its a little clunky I notice, a bit unreliable after the stack is toasted a little.
                                            • 2 / 3
