    DLL callback to ruby
    41 Posts 4 Posters 12.7k Views 4 Watching
      Alienizer
      Thank Dan. So far, everything works great, I even got this to work...
      modUI = rb_define_module('UI');
      menu = rb_funcall(modUI, rb_intern('menu'), 0, nil);
      but I'm stuck on this one...
      rb_funcall(menu, rb_intern('add_item'), 1, rb_str_new2('File/Testing'));
      It tells me "tried to create Proc object without a block"
      Where do you learn all this? I can't find any docs on rb_intern or what to pass to it. I only guess!
      I'm from Mars and moved to Earth to alienize you. Unfortunately, I became humanized.
      • Dan RathbunD Offline
        Dan Rathbun
        The API add_item method takes 2 args, a String and a Block, ... not 1 arg.
        I'm not here much anymore.
          Alienizer
          Indeed! I figured it out, and the rb_intern('menu') takes one, a str of the submenu name, like "Plugins" right?
          When I do rb_intern('add_submenu') with 1 arg of str "Testing", it adds only "T" to the Pluigns menu, the first letter only!?
          If I don't use rb_str_new2 SK crash, Am I doing it right?
          For the Block, do I have to use rb_something to pass the Block, or just the reference pointer?
          Sorry to be a pain in the......
            Dan Rathbun
            At the bottom of the "Extending Ruby" chapter, of the "Pick-Axe" book:
            *ID rb_intern(char name")
            Returns an ID for a given name. If the name does not exist, a symbol table entry will be created for it.
            I just pasted an example that used the rb_intern to create an ID... not sure if it's really needed. You can try just passing a normal string, as the method name argument.
            (Using rb_intern on the C-side, is the same as using a Symbol on the Ruby side, thus:
            :test_item or "test_item".intern or "test_item".to_sym
            What are the arguments, for ruby C-side functions, generally?
            The list at the bottom of the "Extending Ruby" chapter, is not complete, AND that edition was written for Ruby circa 1.6.x (so it's out of date.)
            For a definitive list, refer to to the function prototypes, in the Ruby C source folder:
            %(#000000)[**.../include/ruby-*<version>*/ruby/ruby.h**]
            .. so if your using Ruby ver 1.8.6, the path would be:
            %(#000000)[**.../include/ruby-1.8.6/ruby/ruby.h**]
            ADD: .. and other header files as well.
              Dan Rathbun
              Yea, you need to use rb_str_new2 to convert the Cstring to a Ruby String.
                Alienizer
                Thanks Dan
                  Alienizer
                  Dan, what is the Block expected in rb_funcall(menu, rb_intern('add_submenu')...
                  I keep getting the error "tried to create Proc object without a block" if I use 1 arg.
                  If I use 2 arg, I get "wrong number of arguments (2 for 1)" but even you said it needs 2!? Confusing πŸ˜•
                    Dan Rathbun
                    Not sure... the proc and block functions are listed in intern.h
                    Depends on if the block / proc will be defined at runtime on the Ruby side, or before hand in your C code.
                    This generated doxygen website is old (v 1.8.4) but you may find it easier to find things:
                    http://www.ruby-doc.org/doxygen/current/globals.html#index_r
                      Alienizer
                      Thanks Dan
                        Dan Rathbun
                        @alienizer said:
                        Thanks Dan
                        no problemo ...
                        Also, if you have the Ruby Reference CHM, when you wish to see the C-side source for a method, you can click within the method's definition area, and a source box will unfold.
                          Alienizer
                          Sweet! But only ruby18-core.chm works out of the 3! Or is it me?
                          I just posted http://forums.sketchucation.com/viewtopic.php?f=180&t=39119 another challange for you πŸ˜’ 😳
                            Dan Rathbun
                            ruby18.chm is a wrapper that loads both of the other two, as expandable nodes in the tree control.
                            CHM files use a MSIE stub named hh.exe
                            They a compiled HTML Help Markup files.
                            You can get the HTML Help Workshop app on MS Download.
                              Alienizer
                              Yes indeed, I didn't know the other 2 were loaded into the one. That's a nice ref book! Thanks Dan.
                                Dan Rathbun
                                Well it's supplied with the mingGW compiled Windows Ruby one-click install packages. So I'm not responsible.
                                Check your Private Messages
                                  Alienizer
                                  I know, but I should have figured it out myself 😐
                                    driven
                                    why would you use
                                    Sketchup.send_action(JcB::My_Ext.initalise)
                                    when
                                    works for a loaded file?
                                      Marthmatica
                                      looks like you solved the problem.
                                      If I want to call an rb function, from a loaded rb in SU, you could just send this function from a dll:
                                      Sketchup.send_action my_rb_function_def_name_in_an_rb_loaded_file (no string wrap), as you can other SU commands
                                      which rb SU command, and its function call string is just a string in a class property or in some dll function, thus called in either direction, from dll, or to dll.
                                      Its a little clunky I notice, a bit unreliable after the stack is toasted a little.
                                        Marthmatica
                                        Because I didn't know. Thanks, that'll be better. Any other tips for reliably sending strings and data from DLL's easily?
                                        Is there anyway to extend UI webdialog to contain activex controls? I have not tried it yet, I suppose it is doable. The dilemma is sending external commands to SU, in my case, and that work around is running script functions that have to be loaded, for now.
                                        Also, if you know the browser engine for the UI webdialog, can it be set to a specific browser in SU?
                                        WebDialog.newSketchUp 6.0+
                                        The new method is used to create a new webdialog.
                                        Note that the browser which is embedded inside the dialog depends on the user's OS. On Mac, Safari is embedded, while on the PC whatever version of Internet Explorer is installed will be embedded.
                                        I don't have explorer, thank God, but some engine is being used in SU, just wondering where that may be set.
                                        Just trying to make some easy connectible user dialogs, and experimenting for fun. May be I'll find a hole or two as well, an accidental "in", that's always nice.
                                        Was also wonderign why "creatObject" from the Sketchup encapsulated object model is impossible, I assume, maybe it is not programmed to be accessible. But the exe. exposes the object model, but not many useful methods, eyt I can instantiate the SU object in ActiveX anyways, but I'll keep chipping away the stone. There is more than one hole, and they'll emerge up in time, but I only have a million years here.
                                          Marthmatica
                                          @driven said:
                                          why would you use
                                          when
                                          Oh yeah. Forgot. The reason I was doing this, is to send the send_action "string" (or whatever it really is), from a DLL. And it works sometimes, soemtimes not, and so I was trying to get it to be reliable.
                                          I don't know how to construct a "this.that" thing from a DLL, if that is required to run a ruby command. I just needed to keep the string as simple as possible. Still experimenting. I just need to call SU commands, from outside of SU data forms, even if initiated in SU, as that is all I can do at present. The reason is as usual, the data aids a real IDE may provide, versus naked scripts having to read text and Excel sheets as the "middleman". Just tryign to minimize the back and forth kind of supposed solutions I Frankenstein together.
                                          I really don't know why SU doesn't just expose the whole OM for use by other IDEs. May be it does, but the stupid gene has yet to be naturally selected with myself, and so stupid is what stupid does, take a million years to find a four line solution that works. But, I got a million years, so, might as well do something "extraciricular" while I am here.
                                            Marthmatica
                                            Answering my own post. eval("str") makes this 100% reliable, THAT was my problem. I'll be learning for a while. I'll see if it works on whole chunks of ruby code sends from the DLL.
                                            • 2 / 3
