    Hollander House
    50 Posts 12 Posters 7.9k Views 12 Watching
    • O Offline
      otb designworks
      Thanks Stuart, I appreciate the words of encouragement!
      This video shows all of the common rafters in the kitchen and bedroom set in space and prepped for scribing down into their final positions.
      [flash=853,505:1twfo0n2]http://www.youtube.com/v/gPTbPqg80po&fs=1[/flash:1twfo0n2]
      Cheers, Chuck
      OTB Designworks is on Youtube
        PDS869
        Very cool! It's great to see the progression from pure digital design, through design development, through manufacturing, and finally on to on-site construction.
        • O Offline
          otb designworks
          Here we have all of the kitchen side rafters cut into their final positions and installed.
          [flash=853,505:23emaebf]http://www.youtube.com/v/Yp1iF06-v1o&fs=1[/flash:23emaebf]
          Cheers, Chuck
          • O Offline
            otb designworks
            We are now working on the triple common valley set up, in the shop, that will be joined together with the rest of the frame, outside, once we get as much done inside as is possible.
            This video shows all three of the common valleys, already scribed and cut together, sitting on their cribbing, waiting for the next step, whcih will be scribing and cutting in the ridges that will eventually hold all of the valleys up. We use the SU model extensively for these highly complex setups, as the ability to generate reference numbers and cross check information wherever desired is instrumental to efficient progress.
            [flash=853,505:n3s7ysb5]http://www.youtube.com/v/dN2X-SWo1lg&fs=1[/flash:n3s7ysb5]
            Cheers, Chuck
            • O Offline
              otb designworks
              Once the valleys had been cut together and we verified correct placement in space, we could bring the ridges up, from underneath, the valleys and position them for scribing. Once we ensured that our elevations would match perfectly with the ridges we already have sitting on Old Glory, outside, we could scribe and then cut the housings in the ridges to allow the valleys to sit on the ridges. This video shows the ridges and valleys in their final configuration, ready for us to start placing jack rafters on them.
              [flash=853,505:3cs3us4b]http://www.youtube.com/v/mMVh1W3sgBw&fs=1[/flash:3cs3us4b]
              Cheers, Chuck
              • O Offline
                otb designworks
                We now have the Garage and Entry jack rafters cut into their final locations. As we have 5 bastard jack rafters on each side, outside, we need to cut the common jack rafters into the valleys, in the shop, to match up with the ones outside.
                As this is a complex and precision exercise, we had to fabricate fake ridges, in the shop, to support the jack rafters at the correct pitch, for scribing. This video shows all 10 of them, sitting above the valleys, ready for the scribing procedure.
                [flash=853,505:2qq9tted]http://www.youtube.com/v/Zk2eBlMFRos&fs=1[/flash:2qq9tted]
                Cheers, Chuck
                • W Offline
                  watkins
                  Dear Chuck,
                  I do hope you are making some money on this. It seems an awful lot of work. The mon-hours must stack up to something horrendous.
                  Kind regards,
                  Bob
                  • Bryan KB Offline
                    Thanks for the videos and pictures. I'm just beginning to realize that is one sturdy structure!
                    It's looking good.
                    • O Offline
                      otb designworks
                      Oh yeah, this is one sturdy structure, no doubt about it! And yes, it has been an awful amount of work, especially since I and one other guy have done about 65% of the entire frame by ourselves. πŸ‘Š And I mean the design, the 3D modeling, the renderings, the blueprinting, the shop drawings, the wood procurement, the milling, the layout, the fabrication, the assembly, the crane work, the budgeting, the scheduling, etc, etc...
                      I have to think that this will end up being a once in a lifetime opportunity, especially since it will be awhile before I design something so complex and intricate, unless there is a whole lot of cash available. When you realize that the entire frame has one ridge/peak height and there are 4 ridges, 3 common valleys, and 2 bastard valleys all zeroing out at one post center, it becomes obvious that there was exactly no let up in the perfection needed in the fabrication. With no roof breaks and everything in the same planes, the tolerances were miniscule, even in the normally tight and exact world of timber frames. It makes me tired just thinking about it. πŸ’š
                      Here is the complete common valley system, just before we took it down and started to cut it into the main frame, which is outside the shop.
                      [flash=853,505:2hpihipj]http://www.youtube.com/v/Sa8CE7L4zhE&fs=1[/flash:2hpihipj]
                      Cheers, Chuck
                      • O Offline
                        otb designworks
                        Here is the main frame, with both the Bedroom and Kitchen wings complete. Now that we have finished the valley setup in the shop, we can integrate it into the main frame, which, in my opinion, is the crux move of the entire build.
                        [flash=853,505:rmqi314a]http://www.youtube.com/v/Ntj7XMPPyW0&fs=1[/flash:rmqi314a]
                        Cheers, Chuck
                        • 3 / 3
