    Unicode characters problem
    9 Posts 3 Posters 666 Views 3 Watching
    • voljankoV
      voljanko
      Hello.
      If I put the code
      UI.messagebox "weiß"
      in the Ruby console inside Sketchup,is working ok.
      But the same code inside the plugin is giving me an error.
      I have try it in notepad++ and NetBeans with the some result.
      Why is that,what to do about?
      SuSolid.com - solid check - solid repair- solid intersection check - weight plugin
        Because SketchUp is using UTF-8 encoding - and plugins needs to be written in ANSI. ß is a multi-byte character. If you really need it hard coded in your plugin script then either store it as the raw byte characters.
        Or - you can store the strings in a UTF-8 text file and load it - that will work. I use UTF-8 encoded files for my translations for Vertex Tools. The strings are loaded into a hash file where the keys are ANSI characters.
          More reading on Unicode: http://forums.sketchucation.com/viewtopic.php?f=180&t=20657
          • voljankoV
            voljanko
            Thank you for the very useful reading.
            Seems that is a lot of work to implement multilingual support.
              You mean for the UI?
              • voljankoV
                voljanko
                Yes, I'm implementing my own translation system.Strings are in files,like you suggested.
                • voljankoV
                  voljanko
                  Hello.
                  Another unicode related problem.I can repeat this one only reading from a file,so the file with 1 character is attached.
                  I can read a character,but is causing some problems if I want to unpack it or concatenate it with other strings.
                  Here is the sample,where I want to unpack it:
                  	langfile= Sketchup.find_support_file("fr1.lang" , "Plugins/")
                  	IO.foreach(langfile) do |line|
                  		UI.messagebox line.unpack('U*')
                  The error is :"Error Loading File new.rb
                  malformed UTF-8 character (expected 3 bytes, given 2 bytes)"
                  Why is this,how to deal with it?
                  fr1.lang
                  • Dan RathbunD
                    Dan Rathbun
                    1) Try packing the array with "U3" (and unpacking the String with "U3" also.)
                    2) IO.foreach sets the separator string to $/ by default. ( $/ is set to a newline character by Ruby, and probably should not be changed.)
                    Make sure you write a newline char to the file after the unicode char(s), for each line.
                    ADD: puts() will add a newline char for you, so:
                    ` plugdir = File.expand_path(Sketchup.find_support_file("Plugins"))
                    subdir = "voljanko/xlate"
                    langfile = File.new( File.join( plugdir, subdir, "fr1.lang" ))
                    langfile.puts( ["chars"].pack("U3") )
                    4 bytes should be written, the last should be 10.chr
                    langfile.close()`
                    You may also use IO.read or IO.readlines, but before unpacking, you need to chop() the linestring to remove the record separator ( a "\n" char.)
                    ADD:
                    lines = IO.readlines( File.join( plugdir, subdir, "fr1.lang" )) lines.each do |line| UI.messagebox( line.chop.unpack("U3") ) end
                    3) Your datafiles DO NOT belong in the Plugins folder. Create a subfolder for them.
                    I'm not here much anymore.
                    • voljankoV
                      voljanko
                      The problem was in the file,not in the code.
                      I have saved the file in notepad as UFT-8 ,so I can "unpack" the character.
                      I have tried to save the file in other formats (unicode,ANSI,unicode big endian) and is always giving me errors.
                      So only UFT-8 is ok.
                      Problem solved 😄
