    [Request]Axis Rotate
    3 Posts 2 Posters 448 Views 2 Watching
      andre51
      Hi, I've imported a whole lot of obj files and they came out well but the blue axis need to be rotated 90deg without the model rotating. I know I can do that one at a time but maybe some plugin can automate the process?
      Many Thanks, Andre
      • sdmitchS
        sdmitch
        Andre, I had a simuliar problem recently and I solved it by exploding and re-creating the components which gives them the default axis orientation with the code below
        def reset_axis
          mod=Sketchup.active_model
          ent=mod.entities
          sel=mod.selection
          comps=[]
          if !sel.empty?
            sel.each{|e| comps.push e if e.class==Sketchup;;ComponentInstance}
            for i in 0...comps.length
              dump=comps[i].explode; sel.clear
              dump.each{|e| sel.add e if (e.is_a?(Sketchup;;Face) || e.is_a?(Sketchup;;Edge))}
              grp=ent.add_group sel
              grp.to_component
        http://sdmitch.blogspot.com/
          andre51
          Hey thanks sdmitch! will give it a go..
