🏢 PlaceMaker | 25% off for February including new Google Earth data imports!
Learn more
[question] Copy component or group along path and rotate
Hello everyone.
I ask if anyone know of a plugin which lets you copy a group / component along a path curve and rotate according to
thanks -
Component Stringer should do what you need.
You are right.
use this plugin but I realized all I can do.
thank you very much -
Hi guys, does anyone know of a plugin that would allow me to do this on a closed loop? (ie a circle?)
If you want accurate but not precise, could you just make a tiny break in the circle? Or what degree of arc kills component stringer? 180? 270? 359?
For a repetition along a circle you have the regular tool Rotation + Copy (Key Shift)
