    Platforming minigame
    4 Posts 3 Posters 601 Views 3 Watching
      Mr.K.1
      Since we got into minigames here I want to add another one to the mix: 3D warehouse model: Rob the robot
      I mention mainly so someone would make extra levels, then I can really pull it together into one heck of a model.
      Doesn't even haveto be a working model if you can't figure how it works, I'll put in the proper stuff if you just post the model.
        sketchyKev
        Thanks for sharing this with us. I has a look at your mini game and I see there is a LOT I can learn from you. Your Ruby programming skills and knowledge of SketchyPhysics inner workings is just awesome.
        About the game itself, bumping into your future/past self going about its/your business is mind bending, even more so than the well known "Portal" games. Hopefully you are not doing any damage to the fabric of time and what about the grandfather paradox? πŸ˜›
        • N
          Naththagr8
          Wow, really cool game. I've played something like this but this is way better. However it crashes for me sometimes. Either when I time shifted or at a random moment (the C++ error thing), and sometimes without a message popping up after it closes. So I haven't been able to finish it (plus I still haven't figured out the second level...). Once I finish it I'll try to make up a level or two.
          Naththagr8
          Top Headlines: "Beverly Hills 90210, Cleveland Browns 3"
            Mr.K.1
            Thanks guys, the idea is not actually mine I picked it up from a flash game called Cursor times ten
            I know the game messes up sometimes(freezes on me mostly, then I just reset SP and it's good) but no errors are displayed so I'm not sure what it is that needs fixing.
            But I updated the game so it will skip the tutorial once you pass it, even if you restart it will go to the challenge levels.
            Also you can edit the $intro_stage=0 value to just start at any level.
