    Scooby Doo and Shaggy
    36 Posts 21 Posters 3.1k Views 21 Watching
    • soloS Offline
      How do start out on one of these masterpieces ? Start like you showed us with the evil mouse, or make a block and then sculpt away at it
      Another difficult question, I spend a lot of time pondering this also every time I get an idea for a new model. If it's a cartoon character I usually start with an initial pose, I have a bunch of saved proxy's that I reuse, like the one below, where I have the arm, leg, foot, abdomen and head in separate groups for posing, then stitching and manipulating. The proxy's are created in a way that I have the ability to bend them at certain points without destroying them.
      I then subdivide, add detail, simplify (Artisan reduce poly or just use Artisan smooth feature) Then add more detail and repeat the reduction until I have what I'm looking for.
      • soloS Offline
        An update.
          d12dozr
          These cartoon models are great, Pete.
          I appreciate the little tips about Artisan too! Hopefully in a year or two I can make something with it worth showing off πŸ˜„
          http://goo.gl/f7ooYh
            mimarhamza
            @solo said:
            Thanks guys.
            The head was a little higher poly than I hoped to achieve as I needed to use the sculpt tools to get a likeness then reduce, as much as I could with 'smooth selection' and polyreduce.
            Good job Solo You still can use polyreduce for cheeks and forehead as these parts are more flat than others and one question
            Do you have a symmetry axis for head to make a companent and mirror?
            • soloS Offline
              Do you have a symmetry axis for head to make a component and mirror?
              No, I for some reason cannot get the symmetry to work how I would like it to.
                deanlegg
                Hi Pete
                I don't want to hijack this thread, but is this what you mean?
                sds bike frame.skp
                  deanlegg
                  Sorry should have been this one
                  sds bike frame.skp
                  • soloS Offline
                    Looks great, and yes that's about it.
                    • PixeroP Offline
                      Pixero
                      Shaggy has an amazing resemblance to you Pete. Great work.
                      Just what I thought too.
                      Pete, they look great, but I think you should try to make a lowpoly version with nice edge loops before subdividing to get an even nicer model. Just my two cents...
                      • soloS Offline
                        "edge loops" ? huh? what plugin is that? My mesh is so mangled I doubt I'd ever get looping.
                        I have a way to reduce it better... Deep Exploration, I did reduce it 30% with no loss in detail.
                        I even reduced my SDS version of Wiley by 60% and smoothed it with Artisan for pose rigging.
                        Click on image for larger view.
                        • boofredlayB Offline
                          boofredlay
                          That is so great!
                            deanlegg
                            Can anyone tell me what plugin is FFD please...... and what it does
                            I'm hoping this is the tool to take me to Pete's level
                            • soloS Offline
                              http://forums.sketchucation.com/viewtopic.php?t=6029
                                You should try running Amorph's 'Smoothing' on some of the mesh.
                                • soloS Offline
                                  Forgot about that...thanks Rich, I'll give it a go.
                                  Too many plugin's I forget I have them sometimes.
                                    I know what you mean...
                                    BTW this version of FFD is a tad bit better IMO
                                    http://forums.sketchucation.com/viewtopic.php?t=25801
                                    • 2 / 2
