    MODEL THIS: Loopita Bonita Lounger
    37 Posts 12 Posters 5.5k Views 12 Watching
    • jeff hammondJ
      Yes Dynamic Components are very under used! ๐Ÿ˜’
      But you must make some efforts, it's not "Spontaneous generation" ! ๐Ÿ˜‰
      right, the geometry has to be there in the first place, but, with little bit of creativity, you have all the geometry you need..
      lines can be hidden unless needed and you can use copies to generate new lines etc..
      pretty much the main problem with DCs right now is that you can't control lines/faces unless you make them separate components in which case they lose their ability to make faces in the main component.
        Jeff,
        How does it work? Interact doesn't do anything? I never use DC's so forgive the ignorance.
        • jeff hammondJ
          Jeff,
          fwiw, i never use interact..
          this version is just the raw version of how i'd use it as a calculator while drawing.. i'll make a more polished version w/ user input etc in a little bit..
            This calculator will works only with the Loopita Bonita Lounger model or it's will be universal?
              Not quite identical but I enjoyed the actual maths more than the model. I'll finish the cushions tomorrow if I've time.
              Click for 2000px x 888px
              Make for a nice Render This also ๐Ÿ‘
              • soloS
                Rich, that looks great, I never use DC's so I'm stumped.
                I want to use some sort of stringer but cannot find one that strings perpendicular to the path...anyone know if one exists?
                • jeff hammondJ
                  re: the DC.. look at the screen shot --
                  click pic -> bigger
                  those are all the functions i used showing in the component attributes dialog..
                  i made the rib and set it's axes to 2 1/2' above it as i figured i'd make a 5' inner radius.. (this is changeable if you want and i'll include a height example in the user friendly dc i make of this)..
                  i put 120 for the amount of copies meaning the rib component will be copied 120 times.. for rotX (rotation around the X axis) i put:
                  RotX=0+copy*3
                  which means the first rotated copy will be rotated 0ยบ then every copy there after will be rotated 3ยบ (and 3ยบ * 120 copies = a full circle)
                  for position X (position along the red axis), i put:
                  PosX = 0+copy.35"*
                  which means the first copy will not move sideways along the red (or 0) then each copy after that will shift .35" to the right along the red..
                  • Alan FraserA
                    Alan Fraser
                    I never thought to use a Ruby function. Great idea Jeff. You could probably get the same result by doing the maths then manually moving/rotating the second instance relative to the first, then using AdamB's xformclone.rb which appears in this thread. Obviously, this can be done on the free version.
                    [Edit] Yes...works a treat. I've got RSI now, though. ๐Ÿ˜‰
                    3D Figures
                    • Alan FraserA
                      Alan Fraser
                      I'm going to try to model this for FormFonts. In order to save polygons I'm going to probably ignore stuff like the doubling up of ribs where each section joins the next; and just do a straight array like the ones posted so far.
                      However, I would like to get the geometry right...and it's more complicated than at first sight. You'll notice that the ribs are level at the beginning and end...and also at the TDC...but they they are noticeably banked (like a real rollercoaster) as they go up each side of the loop. That's another function that will need to be calculated.
                      Once the ribs are looking correct; rather than building separate rails, it's probably going to be easier to simply draw the rail profiles on one of the rib components and P/P them to join onto the adjacent one. That will probably require unique components for the flat section at either end, as the rails on the loop are going to have to be slightly skewed.
                      3D Figures
                      • alvisA
                        alvis
                        I see that there are segments of approximately 120 degrees. And they are twisted. This is obvious. Your tests are similar, but incorrect, because the segments are the horizontal and rotated about two points
                        • Alan FraserA
                          Alan Fraser
                          @alvis said:
                          Your tests are similar, but incorrect....
                          Strange that I should get the same result then.
                          3D Figures
                          • alvisA
                            alvis
                            I was talking about the first examples ๐Ÿ˜‰ . your test is really similar ๐Ÿ‘
                            • Alan FraserA
                              Alan Fraser
                              Ah! I misunderstood. Great model BTW.
                              I could see that the actual construction was made up of maybe a dozen sections of 8 or 9 ribs each, so I decided to just do a single array of 96 ribs.
                              If anyone wants to try this from scratch (actual dimensions unknown):-
                              Make a single rib component 30" wide.
                              Make a 5' disc at the side as in alvis's image...to get the centre of rotation for the loop.
                              Make a rotated copy of the rib at 3.75 deg, then using the Move tool on the rotate handles, rotate it by -0.7 deg.
                              Activate the xcopyclone.rb until your finger drops off or you get a complete loop...whichever comes sooner.
                              3D Figures
                              • alvisA
                                alvis
                                not bad not bad
                                • Alan FraserA
                                  Alan Fraser
                                  I kept it as low poly as I could, but it still just topped 6000 faces.
                                  3D Figures
                                  • B
                                    bjornkn
                                    Lots of impressive models here ๐Ÿ˜„
                                    Kind of a new twist on an Ottoman?
                                    If this piece comes flat-packed from IKEA I think I'll pass ๐Ÿ˜‰
                                    • Alan FraserA
                                      Alan Fraser
                                      OK, so who's up for the interior daisy-chain version? ๐Ÿ˜‰
                                      http://blog.decoratrix.com/wp-content/uploads/2009/12/loopita03.jpg
                                      3D Figures
                                      • jeff hammondJ
                                        here's a more user friendly version of the DC.
                                        click on the component then.. Window->Component Options
                                        this example shows one of the major letdowns of DCs (and what i'd love for the SUteam to fix!)..you can't move a component relative to it's axes without stretching it.. so, in order to get proper height control, i had to place the rib component inside another DC.. what this does is create multiple component definitions upon copying which leads to big files sizes/bad performance etc..
                                        obviously not fine tuned etc as i don't have much time to spend on it but you get the idea.
                                        • jeff hammondJ
                                          btw - here are a few real world loops i've built ๐Ÿ˜„
                                          @2:20 = ๐Ÿ˜ฎ
                                          [flash=500,400:2e8irx04]http://www.youtube.com/v/g5ww2vK9n-s?fs=1&hl=en_US[/flash:2e8irx04]
                                          so i almost killed t.hawk once ๐Ÿ˜„
                                          [flash=500,400:2e8irx04]http://www.youtube.com/v/2ZLUZl8sdgY?fs=1&hl=en_US[/flash:2e8irx04]
                                          that ^^^ same loop -- convertible style ๐Ÿ˜„
                                          [flash=500,400:2e8irx04]http://www.youtube.com/v/oJV40gmUtmI?fs=1&hl=en_US[/flash:2e8irx04]
                                          taking the open top loop idea a bit further.. open top corkscrew:
                                          [flash=500,400:2e8irx04]http://www.youtube.com/v/khHTAPr-1P0?fs=1&hl=en_US[/flash:2e8irx04]
                                          can't really find decent videos online of all of them/variations..
                                            Seems a very dangerous model! ๐Ÿ˜ฎ
                                            It's near Paraplegia for some skate users! ๐Ÿ˜ฒ
                                            • 2 / 2
