    Plugin for making button
    4 Posts 2 Posters 662 Views 2 Watching
    • B
      bing1370
      hi can somebody help me where to download a plugin for sketchup to make a button?
      i mean when you make some sofa with button.
      thanks in advance
        d12dozr
        If you mean a just a button like this
        http://www.apartmenttherapy.com/images/uploads/12-19-couch.jpg
        that is easy to do with the native follow me tool. Please describe a little more what exactly you are trying to do...
        http://goo.gl/f7ooYh
        • B
          bing1370
          yes, i've seen here a plugin before, but i forgot the name i was try to download it but everytime my account will logoff,
          if you used your follow me tool as you said how?
            d12dozr
            Make a circle on the ground plane to use as a pathfor follow me, and a vertical circle to use as a profilefor the button:
            Draw a horizontal line just under the center of profilecircle, and erase the bottom arc. Scale the profileshape along the blue axis to get the cross section of a button.
            Select the path, then click on the profilewith the follow me tool, like so:
            If you need a plugin for making the cushion, that's probably the Subdivide and Smooth (or Artisan) plugin...search the "Tutorials" forum for "sofa"...
