    [Plugin] VisMap 2 - Improved Layer/Scene Visibility Map
    41 Posts 21 Posters 29.7k Views 21 Watching
      monkers
      @jsteacy said:
      Everyone, here is the fixed vismap2, hopefully it ends up on the plugin store someday. It runs in 2020 so I assume it's backwards compatible.
      Martin Reinhart is the original programmer but moved on, he gave me permission to find someone to fix it and repost. Turns out my brother-in-law was able to do just that but he doesn't want to be named/credited. All usage/modification should follow Martin's original licensing which I guess is just freeware.
      I'm not a coder, so all I can tell you is how to use it and that the errors went away when I started using the attached script.
      Definitely a great one. Would highly recommend.
      Got it can confirm its working on SU19 I did have to got in and manually remove old versions first.
      Thanks Gents. Appreciate it.
      • 3 / 3
