    Instructor content
    84 Posts 8 Posters 15.1k Views 8 Watching
    • B
      bentleykfrog
      @thomthom said:
      Yea, if we have to specify a path relative to a fixed one we're restrained to the drive the fixed path originates from. 😞
      (unless someone can show of a neat trick around that...?)
      Ohhhh!!!! Just tested, Volume traversal on a mac!
      plugin_path = File.dirname (__FILE__)
      root_dir_entries = Dir.entries(plugin_path+"/../../../../../../Volumes/")
      puts root_dir_entries
      Hmm, if I save a model on my primary hard drive (the hard drive that my user folder is set on and sketchup is installed on) and run model_path = Sketchup.active_model.path in the Ruby console I get the following path: /Users/[my user name]/Desktop/Untitled.skp. But if I save to another drive I get /Volumes/[drive namespace (not the letter)]/Untitled.skp.
      Will have to check on pc.
        Anyone with a non-English SketchUp?
        Sketchup.get_resource_path( 'helpcontent' )
        I'm wondering if the names of files and folders in the Resource folder depends on the current locale.
        • Dan RathbunD
          Dan Rathbun
          @ThomThom: The base of the help content is:
          Sketchup.get_resource_path( 'helpcontent/tool' )
          I'm not here much anymore.
            The base for which Tool.getInstructorContentDirectory base that paths on is:
            See my earlier snippet: http://forums.sketchucation.com/posting.php?mode=quote&f=180&p=314120#pr314106
            Tried and tested under Windows, English SketchUp locale.
            • Dan RathbunD
              Dan Rathbun
              The files MUST be the same name, so that the LangHandler class can find them. (see the 'langhandler.rb' script in the Tools folder.)
              Beneath the 'helpcontent/tool' folder, all the subdirs have numerical names corresponding to tool_id, so they should be the same for all locales.
              I cant see Google changing the names of direct subfolders of the locale folder (but who knows... I guess it's best to check. Perhaps PM Didier, he runs in French right?)
                Full path on my computer:
                C:\Program Files (x86)\Google\Google SketchUp 8\Resources\en-US\helpcontent
                What I'm wondering is if the folders after en-US, the locale folder, might change. That maybe one needs to query the LangHandler for helpcontent ?
                Just like to get it confirmed by a non-English user that the helpcontent folder remains as it is across locales.
                • Dan RathbunD
                  Dan Rathbun
                  Hmmm. why are Chris and the B'frog reporting 4 parent dirs up to the Sketchup dir ?
                  • B
                    bentleykfrog
                    This returns the eraser tool on my system.
                    def getInstructorContentDirectory
                      return "\\21019\\"
                    Its a long way around but I'm thinking that it would be possible to write the required files and folders to the /temp/ folder on the C:/ drive before the tool loads, then use a relative path to the /temp/instructor/ directory in getInstructorContentDirectory. This would avoid the volume traversal problem but I think it would be a bit of a headache.
                    • Chris FullmerC
                      My understanding is that it ia looking in the "tool" folder for content, so it 4 steps back to the base SU directory. This is the path on the machine I am on right now:
                      C:\Program Files\Google\Google SketchUp 7\Resources\en-US\helpcontent\tool
                      That worked for me, are you guys seeing differently?
                      • Dan RathbunD
                        Dan Rathbun
                        Man.. I hate these crappy UI.inputboxes in the SU API !!
                        This is ridiculous !
                          The snippet I posted work for me when I added it to Bezier Tools as a working example. I generate a relative path from Sketchup.get_resource_path( 'helpcontent' )
                          • B
                            bentleykfrog
                            @dan rathbun said:
                            PC:
                            VER = Sketchup.version.to_i USER_PLUGINS = File.expand_path("#{ENV['APPDATA']}\Google\Google SketchUp #{VER}\SketchUp\Plugins")
                            Sorry for the late reply Dan, but on my Windows 7 machine there's no Sketchup Folder, ie. USER_PLUGINS = File.expand_path("#{ENV['APPDATA']}\Google\Google SketchUp #{VER}\Plugins") would work.
                            • Chris FullmerC
                              That is also what I have Niall. What is that extra folder you have there Dan?
                              • Dan RathbunD
                                Dan Rathbun
                                This is the APPDATA path guys, not the Program Files path (or Program Files(x86) if your on Windows 6+.)
                                In the APPDATA path, below the "Sketchup #{VER}" folder, for PRO, there are 3 applet folders:
                                "Sketchup" (where the session.dat file is kept,) "Layout" and "StyleBuilder" folders. Each one of these folders holds user settings and preference files.
                                On Win7, the path should be:
                                " C:\Users\#{ENV['USERNAME']\AppData\Roaming\Google\Google SketchUp #{VER}\SketchUp\Plugins"
                                As I said, on the Mac the User's APPDATA "Plugins" folder is created by Sketchup, but on PC you need to create it yourself, and push the path onto the $LOAD_PATH array to use it for require() or load() calls.
                                If you wish (on PC,) to have user scripts load from the APPDATA path on Sketchup startup, you need to have a script in the "Shared" Plugins folder (the one in the Program Files path,) that has a call using the require_all() method from the sketchup.rb file.
                                Ex:
                                <span class="syntaxdefault"></span><span class="syntaxcomment"># !appdata_load.rb<br /></span><span class="syntaxkeyword">require(</span><span class="syntaxstring">'sketchup.rb'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">VER </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">version</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_i<br />USER_PLUGINS </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">expand_path</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"#{ENV['APPDATA']}\Google\Google SketchUp #{VER}\SketchUp\Plugins"</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">require_all</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> USER_PLUGINS </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span>
                                If you use it, the require_all() method will push the APPDATA plugins path onto the $LOAD_PATH array for you.
                                I do have a Win7 machine in the other room, but have not yet installed Sketchup on it, so... I'm going by what "should be" according to published information. (May be that the Sketchup installer has a mind of it's own.)
                                Addendum: On Win7 (linix-like) you may see a symbolic link directly to AppData, in the My Computer tree that hides the "C:\Users#{ENV['USERNAME']}" prefix.
                                • Chris FullmerC
                                  Sorry Dan, you lost me at "APPDATA". I never knew there was an alternate folder schema somewhere. I'm really not sure what appdata is.
                                  • B
                                    bentleykfrog
                                    +1 on this, sorry for the confusion dan 😳
                                    Time to make a fool out of myself for a second time:
                                    In the snippet you posted earlier, doesn't parts = origin.split( File::SEPERATOR ).size include the separator in the drive name (ie. C:/), so you get x+1 slashes to the root C:/ from helpcontent instead of x, which negates the /tool folder?
                                    Also, just to double-check, is there meant to be an escaping character for w in /^w:/ (ie. /^\w:/) or is something weird going on?
                                    sorry for the noob questions, I really appreciate the responses.
                                      That is a possibility... I might very well be wrong about where it base the path from. But the positive side-effect of my little bug is that it works. 😄
                                      You're right. And it's there in my original code - it seems that the forum ate the escape character! 😮
                                      Lemme try again:
                                      Without PHP formatting:
                                        # Get Instructor Path
                                        # Tool.getInstructorContentDirectory expects a path relative to SketchUp's
                                        # Resource/<locale>/helpcontent/ folder, despite the documentations use an
                                        # absolute path.
                                        # This method is a wrapper that generates a path to the actual help content
                                        # which SketchUp can use.
                                        # The given path must be under the same drive as SketchUp's help content.
                                        # This quick exist in all current SketchUp versions.
                                        # Current; SketchUp 8 M1
                                        def self.get_instructor_path( path )
                                          path = File.expand_path( path )
                                          origin = Sketchup.get_resource_path( 'helpcontent' )
                                          # Check if drive matches
                                          origin_drive = origin.match( /^(\w);/ )
                                          if origin_drive
                                            origin_drive = origin_drive[1].downcase
                                          path_drive = path.match( /^(\w);/ )
                                          if path_drive
                                            path_drive = path_drive[1].downcase
                                            path = path[2...path.size] # Trim drive letter
                                          if path_drive && origin_drive
                                            return nil unless origin_drive == path_drive
                                          # Build relative path
                                          parts = origin.split( File;;SEPARATOR ).size
                                          path_to_root = "..#{File;;SEPARATOR}" * parts
                                          relative_path = File.join( path_to_root, path )
                                          return relative_path
                                      With PHP formatting:
                                      <span class="syntaxdefault"><br />&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Get&nbsp;Instructor&nbsp;Path<br />&nbsp;&nbsp;#<br />&nbsp;&nbsp;#&nbsp;Tool.getInstructorContentDirectory&nbsp;expects&nbsp;a&nbsp;path&nbsp;relative&nbsp;to&nbsp;SketchUp's<br />&nbsp;&nbsp;#&nbsp;Resource/<locale>/helpcontent/&nbsp;folder,&nbsp;despite&nbsp;the&nbsp;documentations&nbsp;use&nbsp;an<br />&nbsp;&nbsp;#&nbsp;absolute&nbsp;path.<br />&nbsp;&nbsp;#<br />&nbsp;&nbsp;#&nbsp;This&nbsp;method&nbsp;is&nbsp;a&nbsp;wrapper&nbsp;that&nbsp;generates&nbsp;a&nbsp;path&nbsp;to&nbsp;the&nbsp;actual&nbsp;help&nbsp;content<br />&nbsp;&nbsp;#&nbsp;which&nbsp;SketchUp&nbsp;can&nbsp;use.<br />&nbsp;&nbsp;#<br />&nbsp;&nbsp;#&nbsp;The&nbsp;given&nbsp;path&nbsp;must&nbsp;be&nbsp;under&nbsp;the&nbsp;same&nbsp;drive&nbsp;as&nbsp;SketchUp's&nbsp;help&nbsp;content.<br />&nbsp;&nbsp;#<br />&nbsp;&nbsp;#&nbsp;This&nbsp;quick&nbsp;exist&nbsp;in&nbsp;all&nbsp;current&nbsp;SketchUp&nbsp;versions.<br />&nbsp;&nbsp;#&nbsp;Current;&nbsp;SketchUp&nbsp;8&nbsp;M1<br />&nbsp;&nbsp;</span><span class="syntaxdefault">def&nbsp;self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_instructor_path</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">path&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">path&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">expand_path</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">path&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">origin&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_resource_path</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxstring">'helpcontent'&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Check&nbsp;if&nbsp;drive&nbsp;matches<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">origin_drive&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">origin</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">match</span><span class="syntaxkeyword">(&nbsp;/^(</span><span class="syntaxdefault">w</span><span class="syntaxkeyword">);/&nbsp;)<br />&nbsp;&nbsp;&nbsp;&nbsp;if&nbsp;</span><span class="syntaxdefault">origin_drive<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;origin_drive&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">origin_drive</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">downcase<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;path_drive&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">path</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">match</span><span class="syntaxkeyword">(&nbsp;/^(</span><span class="syntaxdefault">w</span><span class="syntaxkeyword">);/&nbsp;)<br />&nbsp;&nbsp;&nbsp;&nbsp;if&nbsp;</span><span class="syntaxdefault">path_drive<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;path_drive&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">path_drive</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">downcase<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;path&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">path</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">2.</span><span class="syntaxkeyword">..</span><span class="syntaxdefault">path</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">size</span><span class="syntaxkeyword">]&nbsp;</span><span class="syntaxcomment">#&nbsp;Trim&nbsp;drive&nbsp;letter<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">path_drive&nbsp;</span><span class="syntaxkeyword">&&&nbsp;</span><span class="syntaxdefault">origin_drive<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">return&nbsp;</span><span class="syntaxdefault">nil&nbsp;unless&nbsp;origin_drive&nbsp;</span><span class="syntaxkeyword">==&nbsp;</span><span class="syntaxdefault">path_drive<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Build&nbsp;relative&nbsp;path<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">parts&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">origin</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">split</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">SEPARATOR&nbsp;</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">size<br />&nbsp;&nbsp;&nbsp;&nbsp;path_to_root&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxstring">"..#{File;;SEPARATOR}"&nbsp;</span><span class="syntaxkeyword">*&nbsp;</span><span class="syntaxdefault">parts<br />&nbsp;&nbsp;&nbsp;&nbsp;relative_path&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">join</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">path_to_root</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">path&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;return&nbsp;</span><span class="syntaxdefault">relative_path<br />&nbsp;&nbsp;end<br /></span>
                                        grrr.... the PHP formatter broke the code!
                                        • B
                                          bentleykfrog
                                          Its definitely a positive side effect, and consistent across OS's as macs start with '/' instead of 'C:/'
                                          PHP & escape characters == no love (not even with double escaping), which sucks with Regex. From my experience there's no telling how many processes a php string has been through on a forum post (ie. as written in your own code or copy-and-paste from another website/forum) so I think the php code goes on the singular escape and doesn't bother to check for doubles, which is wrong even if you're formatting php code. I suppose since sketchucation is in php, they've at least got to make the code mute to prevent some pretty easy hacking, by formatting php code as a string. (I'll stop here since its way off topic)
                                          • B
                                            bentleykfrog
                                            Initial testing on the mac works too, though there's no need to copy the instructor files to the temp directory on a mac 🎉
                                            • 3 / 5
