    Render This: Dunny
    74 Posts 30 Posters 19.0k Views 30 Watching
    • honoluludesktopH
      honoluludesktop
      Boo, How did you project the images on the model. Did you scan a image, then project it on the model? Fantastic. If so, does the image go around the model? If it can, how did you accomplish that. I can't believe that you took the time to draw all the surfaces on the model. Did you?
      • boofredlayB
        boofredlay
        First off thanks.
        Which image are you referring to specifically? The only one I drew on the surface was the first one on this post. I drew the eyes and mouth only, the rest was a projected texture. The stone Dunny and Tattoo Dunny were just projected textures. As soon as you rotate around the side you will see the image stretch. No tricks other than getting the right camera angle.
        The grass Dunny was a displacement texture in Thea. Now for the Disco Dunny I started out with a simpler version of the Dunny and used Joint Push Pull (normals) to create the look of individual mirrors glued to the surface. I then applied the mirror texture and that was it.
        Thanks again. There have been some amazing renders of this model. I am glad I made it.
        Edit, for example, the stone Dunny looked like this prior to rendering.
        • pyrolunaP
          pyroluna
          Rendered in V-Ray
            museummaker
            The Silver Dunny Band
            https://lh6.googleusercontent.com/_Mbz1E6DAT2U/TWv_eU2dSYI/AAAAAAAAE6E/hAOdOvIj7N8/s912/theband.jpg
              Starling75
              My God, it's full of stars!
              http://www.youtube.com/watch?v=ou6JNQwPWE0
              http://www.starlingarch.cz
              • urgenU
                urgen
                ....Dunny may be the son of the terminator? 😄
                --pupil forever...------
                • boofredlayB
                  boofredlay
                  Would that be the Dunninator?
                  • urgenU
                    urgen
                    ...maybe it's DunniScнwarzinator.... 😆
                    ....seems to be similar 🤣
                    http://www.etoya.ru/files/images/pub/part_0/7076/Шварценеггер в детсвте_0.jpg?300_300
                    • boofredlayB
                      boofredlay
                      Thea Render
                      http://www.thearender.com/forum/download/file.php?id=6841
                      http://www.thearender.com/forum/download/file.php?id=6840
                      http://www.thearender.com/forum/download/file.php?id=6843
                      http://www.thearender.com/forum/download/file.php?id=6842
                      SketchUp Output
                      • boofredlayB
                        boofredlay
                        I did another render of 84 with Twilight.
                        http://twilightrender.com/phpBB3/download/file.php?id=6019
                        • boofredlayB
                          boofredlay
                          A couple more angles rendered in Twilight.
                          http://twilightrender.com/phpBB3/download/file.php?id=6021
                          http://twilightrender.com/phpBB3/download/file.php?id=6022
                          • V
                            vindemiatrix
                            really nice render 😲 😲 did you know how to make dusty or dirty texrture like in starwars i think of r2d2 how was an old robot thx
                            win 7 64bit , 8go ,nvidia 320gt,intel i3 5300 with two screen perfect for sketchup 22" & 21"
                            • zieiosZ
                              zieios
                              DunnyFigure gold head
                              with RandomControl ARION (32-bit)
                              • boofredlayB
                                boofredlay
                                That would be cool. I am sure it is not too difficult to do dirtmaps with Thea however I have not tried before.
                                Here is a 360 of Dunny84.
                                [flash=853,505:26vllc76]http://www.youtube.com/v/z5kOCMhJtDc&fs=1[/flash:26vllc76]
                                • michaliszissiouM
                                  michaliszissiou
                                  A simple zbrush trick.
                                  • urgenU
                                    urgen
                                    A couple more angles rendered in Twilight.....
                                    ...nice renders,Eric! 😎 👍...Dunninator number84... 😄
                                    • X
                                      xefhs
                                      Wow, nice render ! 😲
                                      How did you textured this rabbit ❓
                                      (What tools/plugins/method did you use, please ? )
                                      Sorry for my bad English, I'm french.
                                      • boofredlayB
                                        boofredlay
                                        Thanks xefhs. There are no textures in this model, just basic colors. All the lines and the 84 are model lines on the surface of the mesh.
                                        To model this I mainly used the Artisan plugin. For the tube I used the bezier spline tools and thenpipe along path.
                                        I then used Twilight Render for the final image that you quoted. I used Thea render for the images farther up the page.
                                        • X
                                          xefhs
                                          Thank you for these explanations ! 😄
                                            Click to enlarge
                                            • 3 / 4
