    Generating Cost Report
    20 Posts 4 Posters 2.0k Views 4 Watching
      pe.ekeberg
      Hi Didier.....in SU8/Plugins/Example/attribute.rb.....a simple report generator......could be extended a bit
      • Didier BurD Offline
        Didier Bur
        OK, I've extended the script a little bit: added a settings dialog box, set up a 'cost per material' output function, and modified the global estimate function so it output results in your local currency (€) and area format (m2).
        That could be a starting point for you if you want to go further with Ruby... πŸ˜‰
        Please read first the file 'costs.txt', where there are some explanations and guides to 'germanize' the script.
        Yes, I supposed you were german, but maybe swedish, danish, norvegian ?
        Hope this helps,
        estimates.zip
        DB
        • KrisidiousK Offline
          Krisidious
          nice Didier...
          By: Kristoff Rand
            pe.ekeberg
            I've downloaded your attributes.rb but the examples.strings was found in my \Resources\en-US\ folder and looks like in the attached file......anything wrong? ....but how do I get the file into my answer?
              Didier Bur
              There is an examples.string in each and every 'resources > en-US' folder, no matter your local version is.
              BUT there is ANOTHER examples.strings file in your local folder.
              From what country are you from ? This will help find your local resouces folder.
              DB
                pe.ekeberg
                Hi......no here in Sweden we use the en-US version with no translation.....have looked into \Document and Settings\ but there are no lokal folders for Resources .....we are rather lucky in one way up here.....we use all media communication in the original language.....of course with the text-translation on in TV
                  Didier Bur
                  If you use the en-US version of SU, your example.strings file is in the ...\Resources\en-US\ folder.
                  Attached is a non-translated version of this file with the new strings added. Overwrite your examples.strings file with this one, re-start SU and it should work?
                  Best,
                  examples.strings.zip
                  DB
                    pe.ekeberg
                    Great Didier.....I got it working at last.....is it possible to add SEK in currency and perhaps also assign estimate to group/groups & components.....just to get an overall Estimate for the project........and can I save the content in Vality Check
                    A lot of questions but it seems a great plugin for Cost etsimation
                    Regards
                    pererik ekeberg
                      Didier Bur
                      What's that ? a file format, an app ?
                      I'll see what I can do for components estimation.
                      SEK isn't a problem (I didn't figure out that Sweden wasn't in the 'euro zone'). Stay tuned πŸ˜‰
                      DB
                        pe.ekeberg
                        After you have Assigned Estimate ti Material you can open Assign Estimate PER Material and then there's a palette named 'Validity Check'....seems to contain all ralavant info for Materials in the rollout in Cost by Material.....by the way why are all material from 'black to <Carchoal> listed if they not been assigned a cost?
                          Didier Bur
                          This new script doesn't list materials that don't have a price/m2 anymore.
                          There was a typo in the menu too, that is fixed.
                          It also adds an option to assign a component a price, and an option to estimate the total price per component and the global total for all instancied components.
                          SEK has been added and becomes the default currency.
                          Beware to overwrite your previous examples.strings file with this one (several strings added in it).
                          Regards,
                          estimatesMatsAndComps.zip
                          DB
                            pe.ekeberg
                            Merci bien Didier.......I'll take up French one of these days
                              pe.ekeberg
                              Very interesting....I have to take up Ruby programming.....could you assign costs to diferent layers.....if you, par example, draw a small building and separating interial and exterial walls to different layers and then attach different materials to the walls you could end up with a cost estimate for the whole building......if one could set different prices to different components as for now it's the last price in for all....what editor do you use?
                                pe.ekeberg
                                Hello.......any good book for trying learning Ruby scripts......
                                • Dan RathbunD Offline
                                  Dan Rathbun
                                  Ruby Resources
                                  And it's in the Developers Forum, that's where we duscuss Ruby Programming for Sketchup.
                                  I'm not here much anymore.
                                    Didier Bur
                                    That's the case now, you can assign a different price for each component.
                                    Notepad++ (can be downloaded here: http://notepad-plus-plus.org/)
                                    With the Ruby color syntaxing and the Sketchup-API-Ruby auto-completion it's a must-have IMHO.
                                    Automatic SketchUp here: http://rhin.crai.archi.fr/rld/automatic_SketchUp.php (smooth learning curve)
                                    Not for now but it's a good idea. Maybe a 'learning/training' exercice for you ?
                                    I've just published the latest version of the script here: http://forums.sketchucation.com/viewtopic.php?f=323&t=35181
                                    You can export the results to a CSV file and open it directly in Excel.
                                    There's a readme for install instructions.
                                    Best regards,
                                    DB
                                      pe.ekeberg
                                      Sorry Dan.....I was just finishing my argueing with Didier with a slightly different question....... β˜€
                                        pe.ekeberg
                                        Thanks a lot Didier....now I have to study for some weeks/months to come......first learning it....then showing it to 'my' Upper Secondary Shool for students in some Building classes to use.....then explaining to the students why it's almost impossible to fully automate the process....
